TR7 Brakes
terryjm1 Terry Merrell
Saint Louis, MO, USA   USA
“I replaced the valve in the TR8 with a new Land Rover proportioning valve with very good results.”
Mind sharing what Land Rover prop valve you used?
Regards,
Terry
In reply to # 1591622 by terryjm1 “I replaced the valve in the TR8 with a new Land Rover proportioning valve with very good results.”
Regards,
Terry
The part number was mentioned earlier in the thread.
I used the LR part out of desperation because no one seemed to have them for the TR8 when I was restoring the car. Since then, they seem to have become available again - don't know why. The only TR8 valves I saw then were on eBay, and people were asking $200 and up for them. The LR valve was $90 + shipping at the time. Physically identical, although if I remember correctly one of the connections was blocked off with a pipe plug. Easily removed, so all the pipes hooked up without modification once I removed the plug.
Hello Gary,
On the uprated servo did you also install the master cylinder that goes with it? I have that servo installed on my TR7 but also installed the matching master cylinder which has a larger diameter piston. I don’t know if installing a standard TR7/8 smaller master would cause your problem but that servo (Leyland Sherpa van) originally came with the larger master cylinder. I installed it as I installed larger front calipers and wanted to move more fluid. It works perfectly.
Regards,
Terry
Vance, thanks. I now see the part number. That is for a Discovery 1.
https://www.lrdirect.com/ANR3194-Brake-Pressure-Reducing-Valve-Ds/
I have a Discovery 1 and have looked at the prop valve many times wondering if it was the same casting as the TR7/8. You can buy them new for about $50. There are even aftermarket suppliers for it. I am installing disc brakes on the back of one of my wedges and will be giving that prop valve a try. Already have larger discs and calipers on the front. Thanks!
Edited 5 time(s). Last edit at 2019-01-23 08:30 PM by terryjm1.
1973 Triumph GT6 MkIII
