silencer bump stop
Pat.L Avatar
New Wilmington, PA, USA   USA
While I was removing the gas tank on the TR8 I noticed a rubber bump stop above the right rear small silencer, but the one on the left was missing. I have looked at various vendors and did not locate one for sale. Does anybody know who makes one or a substitute? Is it very important?
Patrick
1980 TR8 DHC TPVDV8AT209637
TWOA
LaVerne Avatar
LaVerne LaVerne Downey
Fruita, CO, USA   USA
1954 MG TF "Green Hornet"
1969 MG MGB
1979 Triumph TR8 "Wedgie"
When you find out let me know.
In reply to # 1594193 by Pat.L While I was removing the gas tank on the TR8 I noticed a rubber bump stop above the right rear small silencer, but the one on the left was missing. I have looked at various vendors and did not locate one for sale. Does anybody know who makes one or a substitute? Is it very important?
Pat:
That is the bump stop for the rear axle. Instead of getting a loud clunk when the suspension bottoms, you get a soft thud. Rimmer sells replacements, and perhaps others do as well.
They rot and fall out, so if you decide to replace one, do both as you can be sure the other is on its last legs.
Probably made of the same material as the shifter bushings, which are notorious for perishing and causing sloppy shifter movement. All of the shifter bushings were missing on both the TR8 and the Great Pumpkin when I purchased them, as were the rear suspension bump stops. So it is de rigueur to replace them when you purchase a wedge.
darrellwalker Darrell Walker
Vancouver, WA, USA   USA
1966 Triumph TR4A "Christy"
1981 Triumph TR8 "Kate"
In reply to # 1594232 by Darth V8R
Hi Vance,
Pat is correct, there are buffers above the rear mufflers.
-Darrell
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
IMG_0568.jpeg    26.2 KB
Pat.L Avatar
In reply to # 1594240 by darrellwalker
Hi Vance,
-Darrell
You beat me to it Darrell.
Patrick
TWOA
Rear_silencer_Bump_Stop_Left_Side.JPG    41.6 KB
LaVerne Avatar
Fruita, CO, USA   USA
1969 MG MGB
The remains of the two stops on my car were two different lengths.
Hi Vance,
-Darrell
Well, fudge.
I assumed he was referring to the axle bump stop.
It occurs to me that the function is similar. Since the mufflers are floating (not held rigidly in place) they can bang against the frame if you hit a sharp enough bump. So you would want the bump stops in place to prevent untoward noises coming from under the car: "WTF was that sound!?!" eye popping smiley
Mine were completely missing, so I never saw them and I did not know they existed.
Doh!
Pat.L Avatar
The problem is finding replacements. The only vendor I have found to carry a rear bump stop is Rimmers and they only have the axle bump stop. We might be able to use an axle stop if the height is the same.
Patrick
TWOA
In reply to # 1594374 by Pat.L The problem is finding replacements. The only vendor I have found to carry a rear bump stop is Rimmers and they only have the axle bump stop. We might be able to use an axle stop if the height is the same.
I can measure mine tomorrow, but I think they are about twice as high as the axle bump stops.
Darrell Walker
Vancouver, WA, USA
Xseries Brian Ridley-Jones
WATERLOOVILLE, Hampshire, UK   GBR
I will try to find my NOS one and take dimensions and put up a picture. These have not been available since the early 90s.
Brian
Would these work? Bump Stops.
In reply to # 1594466 by Darth V8R
Here are the details on the Energy Suspension site:
https://www.energysuspensionparts.com/9.9166
They give the height as 1.74", which looks to be a tad longer that my originals, but of course they could be trimmed. I can also try to take a more accurate measurement later. They don't give the hole size, however. I also found these:
https://www.energysuspensionparts.com/9.9151
The height is 1 9/16", which looks closer, and they are for a 9/16" hole. Since Pat has an empty hole, perhaps he can check.
-Darrell
Darrell Walker
Vancouver, WA, USA
In reply to # 1594468 by darrellwalker
-Darrell
Darrell:
Damn. This is why I love this forum. With many brains applied to the problem a solution will emerge.
Pat.L Avatar
The hole measures 5/8”. I measured 1 3/4” in height of my existing right silencer bump stop.
I have one new bump stop from my TR7 and it measures 1 1/4” high and 1 1/4” width of top to go into a 1 1/8” hole.
-Darrell
Patrick
TWOA
Bergie Bob Berg
Tarpon Springs, FL, USA   USA
think i ended up using poly bump stops from a jeep wrangler that were a cross fit..same as what pat shows- energy suspension (red) ....have to find the older post......
