Cold start injector not working - how to fix?
Posted by Carb-Dave
Rover827
Rich Truett
Berkley, MI, USA
Feb 2, 2019 08:23 AM
Joined 6 years ago
navydiver
Rob Cornick
san diego, CA, USA
Feb 2, 2019 10:24 AM
Joined 6 years ago
And that’s the reason I try to fix them first! I don’t pay that much for my cars!!
1975 TR7 FHC Ca Spec ACL 4spd
1977 TR7 FHC ACW 5Spd
1980 TR7 DHC FI Spider 5spd
1980 TR7 DHC FI Spider 5Spd
1980 TR7 DHC FI 5spd
1980 TR7 DHC FI 5 spd
1981 TR7 DHC FI 5 spd
Carb-Dave
Dave Mundt
Cedar Falls, IA, USA
![]() 1981 Triumph TR8
Feb 2, 2019 10:33 AM
Joined 5 weeks ago
Thanks all - very helpful info as I dig further into this car. EFI systems with ECUs don't like a dodgy fuel supply.
Looks like I'm going to remove the tank, inspect and flush. (Just did a search online - holy moly - there are no TR8 tanks available anywhere...)
As for draining the tank - I agree, let the pump do the work
Carb-Dave (now EFI-Dave)
Darth V8R
Vance Navarrette
Beaverton, OR, USA
Feb 2, 2019 11:40 AM
Top Contributor
![]() Joined 5 years ago
In reply to # 1593777 by Carb-Dave
This injector is much more reasonable: CJ50.
Carb-Dave
Dave Mundt
Feb 2, 2019 06:52 PM
Joined 5 weeks ago
[/quote]
Thanks...there is now one less cold start injector available for purchase in the world..
Fuel rail pressure looked good - steady at just over 38 psi..at least I have that going for me...still gotta drain the tank.
[/quote]
Carb-Dave
Dave Mundt
Feb 2, 2019 10:34 PM
Joined 5 weeks ago
I'm struggling now with the filler neck removal. But first.....
How do you remove the evap cannister (see below)? Pull up, pull down, twist...I don't want to break anything
Thanks..
Thanks..
darrellwalker
Darrell Walker
Vancouver, WA, USA
Feb 2, 2019 11:00 PM
Joined 3 years ago
In reply to # 1593972 by Carb-Dave
Thanks..
Thanks..
I never did figure out how that comes out, and it felt so brittle that I didn't want to put much force on it in any case. But I didn't need to remove it to get the filler out. If I recall, just unbolt the filler neck from the body from the top, and drop it down with the tank.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
navydiver
Rob Cornick
san diego, CA, USA
Feb 2, 2019 11:41 PM
Joined 6 years ago
I seem to remember it’s in a sort of key hole so you lever it up and pull away from the panel it’s attached to. The filler neck is secured with 3 screws which are normally buried in crud in the bottom of the plastic trim ring. Once the screws are out the filler neck drops down with the tank. Top tip mark the relationship between the rubber hose and the tank before dismantling so you get the angle right when you put things back
Xseries
Brian Ridley-Jones
WATERLOOVILLE, Hampshire, UK
Feb 3, 2019 08:55 AM
Joined 2 years ago
The workshop manual gives some guidance - see attached carb details. For efi cars the extra instruction is brief....
FUEL TANK
Remove and refit 19.55.01
Follow the instructions for carburetter fitted
vehicles, operation 19.55.01, noting that the
fuel return pipe from the pressure regulator
must additionally be disconnected and reconnected
to the fuel tank.
There is a company in UK (TD Ftichett Ltd) that have the original TR7 fuel tank pressing tools - but only for the single hole tank. However a second hole could be made in a new tank without too much difficulty, the trouble would be the lack of swirl pot and baffles for the efi car.
Brian
FUEL TANK
to the fuel tank.
Brian
Carb-Dave
Dave Mundt
Feb 3, 2019 10:29 AM
Joined 5 weeks ago
In reply to # 1594008 by Xseries
FUEL TANK
to the fuel tank.
Brian
FUEL TANK
to the fuel tank.
Brian
Brian - now I know what the 'ROM' is and have downloaded a pdf copy - thanks! This answers many questions.
Operation remove fuel tank commences today.
Forums
Spitfire & GT6 ·
TR7 & TR8 ·
TR6 Tech ·
TR5 & TR250 ·
TR4 & TR4A ·
TR2 & TR3 ·
Triumph Performance ·
Buy, Sell & Trade ·
Vendor Market ·
Herald & Vitesse ·
Stag, 2500 & 2000 ·
Roadster & Pre-War ·
Odds & Ends ·
The Pub - Off Topic ·
List Archives ·
Motorsports ·
Meetup
