Sill Trim
Sill Trim
  This topic is about my 1971 Triumph TR6
19381945 Silver Member Bob Allen
Port Orange, FL, USA   USA
When I bought my car it was missing several parts, one of which was the sill mouldings. Were these standard on the 69 - 72? The car was repainted at some point from blue to red so they could have been left off. I just received new ones from Moss with the 14 clip/rivets. Is there anything special I should know besides marking a straight line and snapping the trim on the seven rivets. Exactly where does the trim go. Just below and even with the sill? Any all suggestions welcome. A closeup picture would help greatly. THANKS.
Bob
KenKKSU Silver Member Ken Kreiner
Aurora, OH, USA   USA
are there not holes in the body for the clip/rivets to fit into?
-1 Yes No Thank
ed.h Ed Hollingsworth
Omaha, NE, USA   USA
Bob--
This should give you some info on the trim:
http://bullfire.net/TR6/TR6-118/TR6-118.html
Ed
LFMTR4 Avatar
LFMTR4 Lou Mijares
Scottsboro, AL, USA   USA
You don’t snap on to, you slide it over them from one end. IIRC it was from the front of the car to the rear.
Thanks Lou, you saved me from what could have been a costly mistake.
Bob
Omaha, NE, USA   USA
Mine just snapped on. The trim strips (at least the originals) were plenty springy enough for this.
Ed
Thanks Ed, I think your right. But, before I try either method I’m going to see if I can snap one in by hand.
Question; were the originals 3/8” wide? The ones from Moss are that size. In some pictures I’ve seen they look at least 1”.
Bob
Omaha, NE, USA   USA
I just measured them. A hair over 3/4" installed.
Ed
LFMTR4 Avatar
LFMTR4 Lou Mijares
There are two widths, the narrow one was fitted until comm. numbers starting with CF and the wider one later. My car (72) has the narrow. I can measure it in the morning if needed but 3/8” sounds about right.
Omaha, NE, USA   USA
I had no idea. I wonder if that explains the difference in installation (snap on vs slide on).
Ed
I've put on a few of each and all were installed with a rubber hammer with a slight tap at the stud.
If you have to hit it, something is amiss.
Yes on the two types, wide of later and skinny on early..
Thanks to Ed, Lou and Wayne. The 3/8” I got from Moss are very sturdy so all I need to do now is head to Harbor Freight for a rubber mallet.
Bob
Omaha, NE, USA   USA
On mine (the wider variety), i just used the heel of my hand.
Ed
Thanks Ed, I’ll try that first.
Thanks Lou, I will carefully try sliding.
