Problem removing center dash support - to get at tranny
BigChill Avatar
BigChill Big Chill
Norwood, MA, USA   USA
Hello,
In my never ending quest to do "just one more thing" on my project car, I got an A type overdrive!!!
My car is a '75 but around 1984 it had its frame replaced (yepp, basically a frame off restoration) by a professional British car mechanic. Good for me, I have not had any issues, at least no major ones. With the car that is... smiling smiley
The replacement frame came from a '72 or earlier, which allow me to install the A type OD - Yea.
So I need to uncover the transmission. Seats came out easy, bolts for the center support required some futzing, but no big deal. I took off the shifter knob, the vinyl boot and the rubber boot.
I am having trouble getting the mount to clear the shifter lever arm.I have it into reverse.
Any tricks or insights from the group?
Thanks in advance,
Big Chill
If you've removed the gear shift lever boot, grommets then remove one more 'screw' and you can twist and remove the cap. Once that's done, just pull out the lever entirely....and don't loose track of the 'anti rattle' components.
ZS carb repairs
kencorsaw@aol.com
Uberxy Avatar
Uberxy Steve Fox
I remember removing the shift knob but I didn’t remove the shifter, for sure.
SR
73 TR6
86 930
Me either, but I thought I'd describe an option.
ZS carb repairs
kencorsaw@aol.com
Steve, pull it straight back down the floor, then up and shift into first. Other than that, Ken suggestion works great. That little pin is a bugger.
BigChill Avatar
BigChill Big Chill
As usual, thanks to all for the advice. This "collective mind" thing often works.
I did need to remove the shifter knob, but not the shifter arm. I did need to remove the radio from the unit.
Pulling the bracket straight back was the trick, once the radio was off, then I could pull bottom toward the rear and get it over the shifter.
Be well everyone.
Big Chill
tirebiter Jeff Garber
Dighton, MA, USA   USA
damn pesky radio
BigChill Avatar
BigChill Big Chill
Actually, the Bentley manual does not mention removing the radio.
But my old Haynes manual explicitly states that you must remove the radio...
Big Chill
LFMTR4 Avatar
LFMTR4 Lou Mijares
Scottsboro, AL, USA   USA
That could be because they didn’t come with a radio, it was dealer installed. That’s also why there is myriad of antenna locations.
