1973 TR6 interchangability for parts with a 1971
Posted by tennee9899
tennee9899
Russell Crouch
Brentwood, TN, USA
Feb 11, 2019 12:40 PM
Joined 22 days ago
A question. If I purchased an entire 1973 (or other year) car to use for a parts car as I work on my 1971 TR6, would most of the parts work on a 1971? Thx in advance for all input.
tirebiter
Jeff Garber
Dighton, MA, USA
Feb 11, 2019 12:47 PM
Top Contributor
![]() Joined 11 years ago
Yes mostly but there are myriad small parts that won't be "correct". I'll leave it for the accomplished librarians and historians on here to point out all of them for you.
tennee9899
Russell Crouch
Brentwood, TN, USA
Feb 11, 2019 12:54 PM
Joined 22 days ago
Thx. So, I'm thinking most of the large items, doors, fenders, bumpers, motor, carbs, dash, wheels, radiator, would fit and work?
Tonyfixit
Tony M
Duncan, BC, Canada
Feb 11, 2019 01:28 PM
Top Contributor
![]() ![]() ![]() ![]() ![]() Joined 2 years ago
Yes. There is also an option of Mixing and matching from other cars, as you noted by the GT6 springs.
barcalude
Dave B
Baldwinsville, NY, USA
Feb 11, 2019 02:51 PM
Joined 2 years ago
Yes...and invaluable for odd parts and ability to see what something should look like e.g. how something should be mounted, routed, etc...
10111775
Dan Hogan
High Rolls, NM, USA
![]() 1971 Triumph TR6 "FrankenTriumph"
Feb 11, 2019 04:57 PM
Joined 11 months ago
Yes, most will fit, hence my 71 "Franken Triumph". It came with a 73 engine that was shot, replaced it with a 71 which works well, I used the 73 intake manifold which may have been a mistake as I think the ports do not align right but do have the older one. Looking in the manifold the newer one had a much better looking runner set up so I used that one. The dash is not a direct replacement as switch cut outs are different. The seats are different but interchangeable. Lots other things especially emissions stuff and compression ratio are different but can be made to work.
Hope this helps
Hope this helps
M. Pied Lourd
Pied Lourd
Newmarket, ON, Canada
![]() 1973 Triumph TR6 "Pearl"
Feb 11, 2019 05:08 PM
Joined 10 years ago
Maybe Poolboy will jump in here to help me out, but you may want to avoid the 73 carbs as I believe they are the least desirable of all years.
Cheers,
Tush
1959 TR3A
1960 TR3A
1962 TR4
1968 TR250
1973 TR6
1981 TR8
1981 Alfa Spider Veloce
Cheers,
Tush
1959 TR3A
1960 TR3A
1962 TR4
1968 TR250
1973 TR6
1981 TR8
LFMTR4
Lou Mijares
Scottsboro, AL, USA
![]() 1972 Triumph TR6
Feb 11, 2019 05:21 PM
Joined 11 years ago
They are but they can be used, it’s the seat belt interlock that you want to throw away. I believe there will be a lot interchangeability.
poolboy
Ken D
Sandy Hook, MS, USA
Feb 11, 2019 06:53 PM
Top Contributor
![]() ![]() Joined 7 years ago
In reply to # 1595974 by M. Pied Lourd
Cheers,
Tush
Cheers,
Tush
Yeah, they are Tush, at least in my book they are...
As far as what they can do when everything is working properly, they are as good as any TR6 carbs. It's just that float chamber vent transition mechanism they tried out in the 73 carbs to make the Anti Run-on Valve innovation effective is a little fragile and it could mess up the quality and stability of the idle.
Someone else must have thought so too, because the next year and from then on it was a more robust arrangement.
ZS carb repairs
kencorsaw@aol.com
Forums
Spitfire & GT6 ·
TR7 & TR8 ·
TR6 Tech ·
TR5 & TR250 ·
TR4 & TR4A ·
TR2 & TR3 ·
Triumph Performance ·
Buy, Sell & Trade ·
Vendor Market ·
Herald & Vitesse ·
Stag, 2500 & 2000 ·
Roadster & Pre-War ·
Odds & Ends ·
The Pub - Off Topic ·
List Archives ·
Motorsports ·
Meetup
