Vin Tags
Posted by briarpatch
Vin Tags
briarpatch
Grant G
Kennewick, WA, USA
Oct 19, 2016 06:09 PM
Joined 4 years ago
As I understand it, there are two tags on the TR4A bulkhead, under the hood. One is the manufacturers plate and the other the VIN plate. One on the drivers side and one on the passenger side. Can some one tell me if this is the VIN plate? Thanks, Grant.
Re: Vin Tags
#2
Vila
Robert Beers
Mechanicsburg, PA, USA
![]() 1933 Chevrolet Master "The 33"
1962 Triumph TR4 "The TR4" 1964 Vespa VNB 125 "The Old Vespa" 1984 BMW 633CSi "The 633" & more |
Oct 19, 2016 06:32 PM
Joined 10 years ago
The photo shows is referred to as the Body Number tag and it should be on the right / passenger side.
The Commission Number tag is wider and for a TR4A contains the Commission Number and two other two digit numbers for both the original exterior color and interior color codes. This tag should be on the left / drivers side. The Commission Number is what they refer to as the VIN today.
Vila
Edited 1 time(s). Last edit at 2016-10-19 06:45 PM by Vila.
Vila
Re: Vin Tags
#3
briarpatch
Grant G
Kennewick, WA, USA
Oct 19, 2016 06:40 PM
Joined 4 years ago
Thanks. I am restoring a car that was purchased by a friend in 1986 in Georgia. It hasn't been on the road since. I was ordering a top for it and Rimmer questioned my VIN number. My car is presently at my brothers house in another state so I asked him to send me a photo of the VIN plate. I nearly had a heart attack when I saw the tag that was different from my title. And it is the same as a VIN number. But thanks for making the distinction clear. I breathe easy again.
Re: Vin Tags
#4
Desert TR
Jim P
Albuquerque, NM, USA
![]() 1966 Triumph TR4A
Oct 19, 2016 07:30 PM
Top Contributor
![]() Joined 5 years ago
Grant,
I'm a bit surprised they asked you for a VIN number. VIN is an American identification. Here is my commission tag. The commission number is a sequential serial number. "CTC" indicates it's a TR4A. The first TR4A was CTC 50001. The "L" stands for left hand drive. If it had factory installed overdrive, the "L" would be followed by an "O". Paint code "25" is Triumph Racing Green or Conifer Green. The "H11" indicates a black interior with leather seats. Factory installed options included disc (standard) or wire wheels (hex nut or spinner nuts), Radial (standard) or Bias ply tires. IRS or live axle. These options were recorded by the factory, but not coded on the tag. All other options were dealer installed. Attached is a copy of the dealer option brochure for the TR4A.
Jim
Jim
Re: Vin Tags
#5
briarpatch
Grant G
Kennewick, WA, USA
Oct 19, 2016 07:41 PM
Joined 4 years ago
They wanted the "number" because the early TR4A's were caught between the TR4 and TR4A's. I did send them photos of the top bows. My VIN is CT 55621L. My body number is CT55441, I think. The engine number is CT55729E. Color was wedgwood blue. Interior was midnight blue leather.
Re: Vin Tags
#6
oldbagpipe
Alec Buchan
Bellingham, WA, USA
![]() 1962 Triumph TR4 "Blue Caboose"
1966 Triumph TR4A 1967 Triumph TR4A 1968 Triumph TR250 "The 'Project" |
Oct 19, 2016 07:49 PM
Joined 3 years ago
Is there any way to find the original color, ... for older ones? I have a '62 and other than the body tag and the commission tag (CT 55xx L), I have nothing.
Re: Vin Tags
#7
briarpatch
Grant G
Kennewick, WA, USA
Oct 19, 2016 07:54 PM
Joined 4 years ago
Re: Vin Tags
#8
oldbagpipe
Alec Buchan
Bellingham, WA, USA
Oct 19, 2016 08:00 PM
Joined 3 years ago
As per multiple sites:
1961: CT1 to CT 2470
1962: CT 2471 to CT 18403
1963: CT 18404 to CT 28485
1964: CT 28486 to CT 40000
1965: CT 40001 to CT 40304
1965: CTC 50001 to CTC 63736
1966: CTC 63737 to CTC 75000
1967: CTC 74001 to CTC 78684
all numbers are said to be +/-
Mine is four digits, 55xx.
Re: Vin Tags
#9
Desert TR
Jim P
Top Contributor
Sorry, I forgot your's was a 1965. The early TR4As still used the "CT" rather than the "CTC". Your top is clearly a TR4A. I'm guessing you were ordering the rubber bumpers (615561) and checking on the number in the package. You can get a certificate from the British Motor Industry Heritage Trust that shows the factory information, but you already have most of what is included and they are not cheap. (Over priced? ) It just verifies what came with the car.
Jim
http://www.heritage-motor-centre.co.uk/store/heritage-certificates-and-archive-services/heritage-certificates.html
Jim
Triumph BMH Cert.pdf 1.32 MB
Re: Vin Tags
#10
Desert TR
Jim P
Oct 19, 2016 08:01 PM
Top Contributor
Re: Vin Tags
#11
oldbagpipe
Alec Buchan
Bellingham, WA, USA
Oct 19, 2016 08:09 PM
Joined 3 years ago
My apologies, I don't mean to take away from the original post, but this may help others with a similar question. Mine is a '62 with no paint code (I have a sneaky hunch, my 'blue' isn't stock...)
Edited 2 time(s). Last edit at 2016-10-19 08:13 PM by oldbagpipe.
Re: Vin Tags
#12
Desert TR
Jim P
Oct 19, 2016 08:27 PM
Top Contributor
I did some quick checking.
Alec, your car is an early TR4. You can get the color number from BMIHT. You don't have to invest in a certificate. For six pounds, they will answer a single question via email.
http://www.heritage-motor-centre.co.uk/store/heritage-certificates-and-archive-services/archive-research-services.html
The confusion over numbers of TR4 and TR4A is that Alec has an early TR4 with a commission number under 6,000. In this case CT55XX.
Grant, If your car has a number over 50001 and a "CT" designation, that means it is a TR4A with a solid or live axle. The"CTC" indicates IRS.
Jim
Jim
Re: Vin Tags
#13
oldbagpipe
Alec Buchan
Bellingham, WA, USA
Oct 19, 2016 08:33 PM
Joined 3 years ago
Thank you, I placed my order and we will see what color (colour) it was....
Edited 1 time(s). Last edit at 2016-10-19 09:04 PM by oldbagpipe.
Re: Vin Tags
#14
TR3driver
Randall Y
Confusion, Los Angeles, USA
Oct 19, 2016 08:46 PM
Top Contributor
![]() ![]() ![]() Joined 6 years ago
In reply to # 1407773 by Desert TR
My understanding is that "CTC" indicates a car with IRS, while only "CT" indicates a live rear axle. Mentioned in Piggott and the Moss catalog. According to Piggott, even the pre-production 4As had the "CTC" prefix.Randall
Re: Vin Tags
#15
Desert TR
Jim P
Oct 19, 2016 08:52 PM
Top Contributor
Randall,
That's correct. I indicated the same in my last post (#12). That's what happens when you post without checking your (my) information.
I realized it when I looked at the TRA judging guidelines.
Jim
Jim
Forums
Spitfire & GT6 ·
TR7 & TR8 ·
TR6 Tech ·
TR5 & TR250 ·
TR4 & TR4A ·
TR2 & TR3 ·
Triumph Performance ·
Buy, Sell & Trade ·
Vendor Market ·
Herald & Vitesse ·
Stag, 2500 & 2000 ·
Roadster & Pre-War ·
Odds & Ends ·
The Pub - Off Topic ·
List Archives ·
Motorsports ·
Meetup
