TR4 Wing Vents my new project
  This topic is about my 1964 Triumph TR4
rod-h Avatar
rod-h Silver Member Rodney Hamilton
Lago Vista, TX, USA   USA
I have been dealing with heat soak issues on my TR4. I have done some research on the rally style wing vents such as sold by Revington TR. They are pricey and it means a lot of body work to install. So I came up with an alternative.
I'm using Land Rover side vents. They are a reasonable facsimile to the factory vents and with careful cutting can be installed without having repaint the bodywork.
I'll fabricate the tunnel pieces and the backing flange using carbon fiber (styrofoam and vacuum bag).
I picked up a Triumph Herald grille off ebay which I'll use to make the insert.
I'll keep you posted...
The older I get the more cynical I become, but, I can't keep up.
Edited 2 time(s). Last edit at 2019-01-24 03:31 PM by rod-h.
Factory Wing Vent.JPG    26.3 KB
IMG_3137.JPG    46.6 KB
IMG_3138.JPG    47.6 KB
IMG_3166.JPG    39.9 KB
bteichgraber Avatar
Tsawwassen, BC, Canada   CAN
Cool. Like to see the finished pictures
Geo Hahn Avatar
Mt Lemmon, AZ, USA   USA
Nicest one I've ever seen in person:
Worst was a local TR6 owner who used a pair of stick-on vents (no holes, just show).
M. Pied Lourd Pied Lourd
Newmarket, ON, Canada   CAN
1973 Triumph TR6 "Pearl"
Hi Rod,
Good luck with your project.
I’ve done the wing vents on my TR250 project. Not completed fully yet but the hard part is done.
Tush
1959 TR3A
1960 TR3A
1962 TR4
1968 TR250
1973 TR6
1981 TR8
1981 Alfa Spider Veloce
rod-h Avatar
Thanks for the encouragement. Tush, your vents came out awesome. Beer and cutting tools, sounds like a good time eye popping smiley
A little more progress today. I made the tubes to go from the outer fender to the inner fender.
Edited 2 time(s). Last edit at 2019-01-25 02:20 PM by rod-h.
IMG_3144.JPG    41.8 KB
IMG_3152.JPG    60.1 KB
IMG_3164.JPG    42.6 KB
malbaby Avatar
malbaby malcolm baker
kyabram, Australia   AUS
Rodney...Yours is a pristine looking car...as a matter of interest to me, are side vents proven to be effective.
Did you consider buying another hood and modifying it with louvers.
rod-h Avatar
Thanks for the suggestion, I had not considered louvers. My car is already bastardized by the purist standards, so I’m not concerned about original body work getting holes in it.
The few people I’ve talked with that have wing vents are claiming - 15 degrees.
Rod
malbaby Avatar
Wonder what the difference in cooling effect would be...side vents versus hood louvres.
There is also the question of water ingress, depending if you drive in rain.
Easier to buy another hood than repair fenders and inner guards if the side vent cooling is not to your expectation.
Edited 1 time(s). Last edit at 2019-01-30 06:10 PM by malbaby.
Geko Avatar
Geko Stef SG
Cheap and effective alternative...
IMG_3264.jpg    60.1 KB
IMG_3263.jpg    41.3 KB
JimG Avatar
JimG Jim G
Aurora, CO, USA   USA
Interesting your plug didn't crush under vacuum. I considered this method for my air box but in the end used machinable wax as a plug
to make the mold. I love working with carbon fiber. I made velocity stacks for my old Mikunis that were so light it just seemed unreal.
The part is looking good though.
jg
Motor1.jpg    49.4 KB
IMG_2072.JPG    53.4 KB
olivier31 Avatar
olivier31 Olivier VIDAL
MURET, France   FRA
Wing vents really improve cooling ... Too much ? winking smiley
rod-h Avatar
Stef: I actually tried something similar, but, I realized air in was not the problem. Air out is. With the honda drive train there is not much room around the engine for air to go out. So, I pushing air in and it does not flow out. I tested this by placing a short 2 x 4 between the bonnet and latch to hold the hood open about 2 inches, temps went right down. With air scoop open cockpit temperatures went right up.
JimG: Really nice work with the carbon fiber. Mine is not nearly as nice, but, is hidden.
Oliver: Summers in Texas never look quite like that winking smiley
Things are coming along:
The Herald grille I sourced is rough (too rough to polish out), so I'm painting the grille inserts the metallic silver color of the bonnet stripe, the wing vent surrounds are painted the color of the car.
IMG_3172.JPG    63 KB
IMG_3176.JPG    44.3 KB
IMG_3185.JPG    37.9 KB
rod-h Avatar
Updates:
I go to the scary part cutting through the fender and inner fender without incident.
I made a Top Hat section out of carbon fiber to slide into the tube I made that attached to the outer vent section. Then I cut. I
After cutting and grinding (very carefully) it was time to assemble the whole mess. The Land Rover vents have clips to hold them to the body, but, I used a little Auto Body Panel adhesive to hold everything in place. I painted the Triumph Herald grille bits the color of the bonnet stripe (dark grey metallic silver) only with the vertical slats in flat black.
and this is what it looks like finished.
IMG_3197.JPG    62.5 KB
IMG_3199.JPG    38.2 KB
IMG_3205.JPG    45.7 KB
IMG_3206.JPG    59.4 KB
IMG_3209.JPG    55.7 KB
rod-h Avatar
Here's an original vent with mine underneath. I think I'll refer to mine as a "homage" wing vent
christopizza Avatar
christopizza CHRIS S
YOUNGSVILLE, NC, USA   USA
1954 Triumph TR2 "Clarence"
1959 Triumph TR3 "Cheddar"
1963 Triumph TR4 "Photene"
1969 Triumph TR6    & more
I had the same idea, but haven't gotten around to it. Super cool to see an alternative vent approach!
1954 TR2 long door "Clarence"
1963 TR4 German import "Photene"
1969 TR6 - needs a new home "Rusty"
1973 TR6 - needs paint - mechanicals completed "The Pig"
