I am installing a new exhaust system into a 1966 TR4A solid axle and the previous system was lacking quite a few bits and pieces one of them being the part number 16 in the attached image. My question is what exactly should I be attaching the support flange (#16) to? The transmission, the frame? Any help would be appreciated.
Thanks, Ed
Ehaust support flange
Posted by TrippingTR
TrippingTR
Edward O
Phoenix, AZ, USA
![]() 1966 Triumph TR4A
Jan 11, 2019 06:16 PM
Joined 7 months ago
Geko
Stef SG
Kuala Lumpur, WP, Malaysia
Jan 11, 2019 07:29 PM
Joined 4 years ago
To one of the 2 big GB bolts, the bracket nut will hold the GB and rubber mount together. Beware that aftermarket brackets fracture frequently because of vibrations. Some make their own with ticker steel or add a steel plate to the original or weld a nut to it, some merely delete it. Be sure that it WILL fracture in no time if you don't strengthen it.
Edited 1 time(s). Last edit at 2019-01-11 07:38 PM by Geko.
mgruber921
Marvin Gruber
Florence, AL, USA
![]() 1968 Triumph TR250
Jan 11, 2019 07:57 PM
Top Contributor
![]() Joined 7 years ago
Goes under trans mount on right side. Use big bolt that goes thru trans mount hole. Most are thrown away. I have several if wanted Marv
TrippingTR
Edward O
Phoenix, AZ, USA
Jan 11, 2019 09:18 PM
Joined 7 months ago
jerryvv
Jerry Van Vlack
Hudson, USA
Jan 12, 2019 05:14 AM
Joined 6 years ago
I would not delete this bracket, you'll end up with vibrations and even a rattle of pipe to frame at some point. It was designed and placed there for a reason.
ducbsa
Bruce Metcalf
Berryville, VA, USA
Jan 12, 2019 06:41 AM
Joined 4 years ago
TrippingTR
Edward O
Phoenix, AZ, USA
Jan 12, 2019 10:23 AM
Joined 7 months ago
No plan to delete it, just need to know where it goes exactly. Marv helped me out there. Thanks!
Vila
Robert Beers
Mechanicsburg, PA, USA
![]() 1933 Chevrolet Master "The 33"
1962 Triumph TR4 "The TR4" 1964 Vespa VNB 125 "The Old Vespa" 1984 BMW 633CSi "The 633" & more |
Jan 13, 2019 10:31 AM
Joined 10 years ago
You can see where it goes in the attached graphic.
If it is the same location as a similar bracket on my 62 TR4, then it attaches to one of the bolts on your transmission mount.
Just look at that pipe joint at the aft end of the forward muffler pipe, the transmission mount should be just above that joint. I believe it uses the right bolt that attaches the transmission mount to the chassis.
Vila
Edited 1 time(s). Last edit at 2019-01-13 02:31 PM by Vila.
Vila
Forums
Spitfire & GT6 ·
TR7 & TR8 ·
TR6 Tech ·
TR5 & TR250 ·
TR4 & TR4A ·
TR2 & TR3 ·
Triumph Performance ·
Buy, Sell & Trade ·
Vendor Market ·
Herald & Vitesse ·
Stag, 2500 & 2000 ·
Roadster & Pre-War ·
Odds & Ends ·
The Pub - Off Topic ·
List Archives ·
Motorsports ·
Meetup
