rebuilding TR3 brake and clutch cylinders
T-time Avatar
T-time Barry O
Milton, ON, Canada   CAN
I plan on using DOT 3 again, as i understand it if I want to switch to synthetic DOT 5 I would need to replace ALL the seals ( rear brake cylinders, clutch slave cylinder) and then totally flush the system
Barry
59 TR3A
68 Mustang
Jacad Avatar
Montreal, QC, Canada   CAN
Barry,
You are quite correct, if you want to switch over to DOT 5 your entire hydraulic system should be totally purged of any trace of the old DOT 3 so not only do you have to drain and clean all your lines but all the old seals need to be replaced.
(Actually, I think that mixing the dots may not be absolutely fatal, but they are not supposed to reside side by side as they will not mix together, so if you do not purge your system you will have 2 different types of fluid in suspension which is probably not a good idea. While I am doubtful that todays rubber seals would be affected by DOT 5 (silicone) mixing could result in uneven braking)
Barry
Edited 2 time(s). Last edit at 2019-02-06 09:37 AM by Jacad.
T-time Avatar
T-time Barry O
no instructions on what direction to put the new seals on plunger, the end one was so worn you couldn't tell which way it went
can someone please let me know if i have them right?
Barry
59 TR3A
68 Mustang
new seals.jpg    24.1 KB
Jacad Avatar
Looks correct, the fatter/hollow end of the seal goes into the cylinder first
Barry
This might help
https://drive.google.com/open?id=1V-Xd9TEycmzzLv6gqDHUM_GxQRsw-7oU
Just my opinion : I would rather run a mixture than straight DOT 3. The two fluids are fully compatible (per DOT requirements), they just don't mix. Traces of DOT 3 left behind will continue to degrade, eventually turning to a gooey mess. But you still get the benefit of not having corrosive DOT 3 in all the places where steel rubs aluminum (which with DOT 3 sets up an electrolytic corrosion cell); and not having it take off the paint when you do eventually have a leak.
I'm not saying that it isn't better to replace all the seals, soft lines and maybe even hard lines (they are some 60 years old after all); just that half a loaf is better than none at all.
TuRtle5 Avatar
TuRtle5 Kevin Kelly
Absecon, NJ, USA   USA
1959 Triumph TR3A "Drandulet"
1968 Triumph TR250    & more
I've switched over my Triumphs to silicone. I don't take everything apart- I open the bleeders, disconnect the master cylinder lines, blow compressed air through the lines until all cleared of fluid, squirt a small amount of starting fluid in the lines and blow it out again. I take apart the M/cyl and spray the parts off with starting fluid, reassemble w/ silicone fluid and all good. I found that after cleaning brake parts with brake-clean, I could still feel something left on the parts (brake fluid). a quick shot of starting fluid (alcohol) and it was gone. Been doing this for years with good results.
