I tried it the service manual's way, (install shock link to plate, install spring to plate with U bolts, then install front spring bolt....). I could not get the front bolt to go through the spring bushing, too hard to align.
So I installed the link loosely, installed the front spring bolt, then the U bolts to the plate. Muche easier.
I also found it hard to install the u bolts as they need to be squeezed together to fit in the plate. After trying various clamps, etc. I settled on a hose clamp. Are the U bolts supposed to be squeezed to install, or are mine bent?
how do you install rear leaf springs?
Posted by brucejon
Santa Cruz, CA, USA
Feb 2, 2019 06:40 PM
Top Contributor
![]() Joined 8 years ago
M. Pied Lourd
Pied Lourd
Newmarket, ON, Canada
![]() 1973 Triumph TR6 "Pearl"
Feb 2, 2019 07:00 PM
Joined 10 years ago
I used a wood clamp to squeeze the u bolts enough to line up with the plate.
Tush
1959 TR3A
1960 TR3A
1962 TR4
1968 TR250
1973 TR6
1981 TR8
1981 Alfa Spider Veloce
Tush
1959 TR3A
1960 TR3A
1962 TR4
1968 TR250
1973 TR6
1981 TR8
Safari
Jim C
New Orleans, LA, USA
Feb 2, 2019 07:04 PM
Joined 11 years ago
I think I used a vice to squeeze the u bolt together.
Thanks Jim
1957 TR3
1958 MGA
1976 TR6
1963 Austin Healey BJ7
1967 Mustang GTA
2005 Lotus Elise
2013 MINI Roadster R59
Edited 1 time(s). Last edit at 2019-02-04 06:39 PM by Safari.
Mt Lemmon, AZ, USA
Feb 2, 2019 07:05 PM
Top Contributor
![]() Joined 1 year ago
TR3driver
Randall Y
Confusion, Los Angeles, USA
Feb 2, 2019 08:23 PM
Top Contributor
![]() ![]() ![]() Joined 6 years ago
I stick the U-bolts in the bench vise and squeeze them a bit, until they fit easily through the plate. IIRC, I install the springs onto the pin & shackles first, then use a jack and a block of wood (if necessary) to lift them against the bottom of the axle. Makes it much easier to add the U-bolts (and get them in the right place) and the plate.
For the ones that were too tall, I couldn't get the spring high enough unless I put the block of wood directly on the plate. Here's a photo of that. (Obviously, this shouldn't be necessary with the correct spec springs).
Crescent City, CA, USA
![]() 1961 Triumph TR3A "Buck"
Feb 3, 2019 11:17 AM
Joined 8 months ago
Wondering on that during drivers side spring removal last night. Removed front pin first, rear shackle had tension on it that complicated removal a bit. Jacking under mounting plate did not seem to affect. I like the idea of making sure ubolts line up to plate prior to assembly and then loosely reassembling, which is the way I was taught anyway.
I read a moss bulletin recently somewhere about not torquing down the leaf spring pin and shackle until the tires are back on and the car is back on the ground. Theory i guess is that the pins and bushings should be subjected to dead load to properly torque? Only place I've seen it. Thinking going to be a lot of fun getting a wrench or socket on that, lift not yet in the budget .
Small shop space practical affordable lift designed for these cars subject worthy of a new forum topic for me, if there are any of you out there experienced in metal fabrication I have an idea that I need help a bit with practical design, hoping to get fabricated locally. I've looked at several different lift manufacturer's on line. Decided on one but need it about 2/3 the size.
Excuse my ignorance in advance. Very little local experience or support available locally.
Temple
Temple
Santa Cruz, CA, USA
Feb 16, 2019 05:57 PM
Top Contributor
So I did the passenger side, and the procedure in the service manual worked fine. Dont know why the drivers side gave me such fits.
Forums
Spitfire & GT6 ·
TR7 & TR8 ·
TR6 Tech ·
TR5 & TR250 ·
TR4 & TR4A ·
TR2 & TR3 ·
Triumph Performance ·
Buy, Sell & Trade ·
Vendor Market ·
Herald & Vitesse ·
Stag, 2500 & 2000 ·
Roadster & Pre-War ·
Odds & Ends ·
The Pub - Off Topic ·
List Archives ·
Motorsports ·
Meetup
