Balancing the fan
Balancing the fan
  This topic is about my 1960 Triumph TR3A
6TTR3A Silver Member Frank Conklin
San Diego, CA, USA   USA
The fan mounting kit that is available includes a part that appears
to have something to do with "balancing" the fan. See attached. The shop manuals say
the fan is factory balanced and be sure to put it back the way you found it.
When I took the fan off, that part was missing (along with the flat washers shown)..
Should I be concerned? If so, how do I go about assembling it correctly?
Let's try that again !!!
Fan kit.JPG    39.9 KB
Jacad Avatar
Montreal, QC, Canada   CAN
Frank,
Fans were balanced at the factory and they were then drilled with a small hole through the fan and through the hub. You will find those holes on both pieces so that you can easily line them up.
That said the fan may need to be re-balanced and you can easily re-balance it by building a jig or using a bubble balance for a lawn mower blade
http://www.britishcarforum.com/bcf/showthread.php?39962-Balancing-a-TR3-fan-assembly
https://www.google.com/amp/s/www.tapatalk.com/groups/triumphregister/viewtopic.php%3Ft%3D4655976%26amp%3D1
Barry
Edited 2 time(s). Last edit at 2019-02-04 06:31 AM by Jacad.
See pages C9-C10 in the workshop manual
https://drive.google.com/open?id=0B2H2NJt34OffYWZiN2VlZGMtNTkxMi00NGUzLWE4NzMtMGRkODRkYzU3MDU1
