I have installed a 10si alternator and I have been investigating fan belts that will work. Looking through the search engine here I have come up with a Gates 24379. I purchased this belt and it is still too small. I have also seen numbers of Gates 28390 and 28400, but I am reluctant to purchase more belts if someone here has used this alternator and has a belt number that will work.
Pat
Patrick
1980 TR8 DHC TPVDV8AT209637
TWOA
Alternator Conversion Fan Belt
Posted by Pat.L
New Wilmington, PA, USA
Jan 9, 2019 01:43 PM
Joined 4 years ago
Santa Cruz, CA, USA
Jan 9, 2019 05:20 PM
Top Contributor
![]() Joined 8 years ago
In reply to # 1588319 by Pat.L
Pat
Pat
Most flaps will allow you to return unused belts. When I did my conversion what worked for others didn't work for me. So I bought 3 or 4 belts and returned the ones that didn't fit. Check to see what your flaps policy is.
Edited 1 time(s). Last edit at 2019-01-09 05:22 PM by brucejon.
miketr362
Mike Euziere
Cocoa, FL, USA
![]() 1962 Triumph TR3A
Jan 10, 2019 01:23 PM
Joined 6 years ago
I am also in the process of looking for a fan belt because of a conversion to alternator. my issue is i didn't convert to the smaller pulleys, and now i can't find a belt wide enough and long enough, ideally i am looking for a 38" by 3/4" (19mm). currently have a 38" by 16MM belt but it squeals something awful. in suggestions on a source?
Mike E.
62 TR3A
Mike E.
62 TR3A
Jan 15, 2019 08:34 AM
Joined 4 years ago
Pat
Pat
I am going to correct this post since the Gates 24379 does fit. At first it did not look to fit at all but in further investigation I did not have the alternator fully positioned toward the block. Also it helped to warm the belt of my garage heater and use a 6 inch pry bar to pull the belt over the pulley. The reason I used this adjustment arm and 10si alternator is I had them from another project that did not work very well. Actually the most difficult part was getting the fan belts between the fan and the radiator. There were times I thought I would need to remove the radiator in order to install a fan belt. Now to figure out the wiring.
Patrick
TWOA
peerlessgt
paul milsom
Llanfair Caereinion, powys, UK
Feb 2, 2019 10:02 AM
Joined 4 years ago
Hi presumably you've done the 1/2" fanbelt conversion. handily the waterpump pullet from the spitfire/gt6 work just leaving the crankshaft pulley. I have done this to my Peerless tr3 engine, and the belt is a v1000 ie 1000mm outside perimeter, hope this helps. otherwise wrap a tape measure round the pulleys, and measure. european belts the number is usually the size. ie, v1000. . if you'e in the states, the belt counter usually has a reference guide with perimeter sizes, etc in it. hope this helps.
Chardon, OH, USA
Feb 2, 2019 03:29 PM
Joined 8 years ago
The conversion sold by Triumph Rescue uses the Gates 24379 with the old style wide pulley. The length needed may depend on the mounting used, i.e. how far the alternator needs to travel on the bracket for correct tension.
Forums
Spitfire & GT6 ·
TR7 & TR8 ·
TR6 Tech ·
TR5 & TR250 ·
TR4 & TR4A ·
TR2 & TR3 ·
Buy, Sell & Trade ·
Vendor Market ·
Triumph Performance ·
Herald & Vitesse ·
Stag, 2500 & 2000 ·
Roadster & Pre-War ·
Odds & Ends ·
The Pub - Off Topic ·
List Archives ·
Motorsports ·
Meetup
