Test fitting help needed
69 Spitfire 12a Avatar
69 Spitfire 12a Chris S
Gilroy, CA, USA   USA
Does anyone in the SF bay area have a spitfire with no motor or trans I can use to test fit an engine?
Saw a Spitfire frame done in cardboard as part of a build.
tapkaJohnD Avatar
tapkaJohnD John Davies
In reply to # 1601129 by 69 Spitfire 12a Does anyone in the SF bay area have a spitfire with no motor or trans I can use to test fit an engine?
What a curious question!
If you have a Spitfire and are fitting a different motor, you could use that.
If you don't have a Spitfire, why you do want to fit an engine to one?
I'd want to know more!
In reply to # 1601230 by tapkaJohnD
John,
I can think of a simple reason. If I had a Spitfire with an engine in it and was thinking of a swap using an engine that I had not heard of being used in a Spitfire before I might want to try fitting it in without pulling my engine out. A Spitfire with no engine and gearbox would make a good go/no go gauge for the swap.
Wolfcreek Steve Steve P
Central, WI, USA   USA
1937 Dodge Magnum "The Dodge"
1947 Unknown Unknown "My Autocar"
1980 Triumph Spitfire 1500 "Vicki's Little Red Car"
Somebody is thinkin'.^^^^^^
70tbolt Avatar
70tbolt Geoff Ullmann
Morgan Hill, CA, USA   USA
What's the engine you are considering? Maybe someone out there has already tried it? Worth a shot.
Geoff
Gilroy, CA, USA   USA
Paul's correct. My spitfire has a motor and id like to keep it on the road till stuff is more ready
and I thought about the cardboard frame, just knew itd be ideal to try a real car if theres one near
I dont think anyone has put Suzuki G motors into spitfires
only seen one done in a Bugeye Sprite
tapkaJohnD Avatar
That explains why you want to borrow a chassis, but not why you want to fit a different engine!
I don't think I've ever heard of anyone fitting a Suzuki G - three or four cylinder?
And will you mate it to a Triumph gearbox, or adapt the Suzuki one?
Harlen19 Avatar
Harlen19 Gold Member John Moore
Chocowinity, NC, USA   USA
I have the front half of a spitfire frame that I was saving for the same purpose. I was going to put a Ford ZETEK in my Spitfire, but decided my current engine ran so well I abandoned the project. I live in eastern NC. Come and get it! I will be here all month.
Harlen19
75 Spitfire
72 GT6
005.JPG    53.7 KB
Johns Spitfire 005.JPG    63.2 KB
Gilroy, CA, USA   USA
Definitely cant get to NC
