Spitfire bad gas/ignition/carburetor idle problem
TheZster Avatar
TheZster Steven Z
SAINT LOUIS, MO, USA   USA
1978 Triumph 1500 "BLK-BRY"
You've gone through 2 tanks of gas... Problem with contaminates there is gone..... water/moisture pools under the gas... and is no longer under your tank level...…. Eliminate that as a problem.... and move forward.....
Z
TheZster Avatar
TheZster Steven Z
DGV.... been there - done that...…
Possibly trash in the system by now - depending on your fuel filter - post tank -.... might have some trash around your carb bowl needle....
I doubt your fuel tank is your issue..... move to the DGV.... ( I assume that's what you've got...)… a minor carb rebuild - with new gaskets/needle/cleaning - should clear it up.... but others might disagree - and right now - all possibilities are open...
Z
Hardrocker99 Avatar
Hardrocker99 Mark Clark
TROY, NC, USA   USA
I am focusing on the carb now. Bear with me, I have a 1979 but there is no manual choke so it is the DGEV carb with the electric choke, correct? Anyone have a rebuild kit recommendation?
In reply to # 1601653 by Hardrocker99 Anyone have a rebuild kit recommendation?
Some will say the best rebuild is to switch to SUs.
Hardrocker99 Avatar
TROY, NC, USA   USA
10-4, Doug. Trying to just use the K.I.S.S. theory on this one. Keeping it simple usually works best for me. :-)
