IS THERE A WASHER BETWEEN THE VERTICAL LINK CENTER SHAFT AND TIE ROD LEVER
mandmind Avatar
mandmind Silver Member MICHAEL DAVIS
COCOA, FL, USA   USA
Is there a washer between the vertical link center shaft and the tie rod lever, the Haynes book I have shows the nut, washer, tie rod lever, washer and vertical link in the exploded view. The parts books show nut, washer, tie rod lever and vertical link.... which is needed, I don't trust it was put together right previously..
thanks
Happy to be clueless
I'll try anything
Mikey
The washer takes the bind off the arm coming across the vertical link. Makes it set flat.
This is a photo I put together some time ago. It shows the setup as in many parts books and repair manuals. I don't think this has changed over the life of the car.
This question got me curious so I went searching and looking/. I checked Mk3, MkIV and 1500 repair and parts manuals and all of them show a washer in that space between the steering arm and the upright. However, none of my cars have one there and if there was one there it would be necessary to also have a matching one added to the secondary bolt position where the dust shield mounts. (I notice there are very few books that show the dust shields in place. They are left out of most parts diagrams. ) From what I can find there is no washer needed or wanted between the steering arm and the main upright where the stub axle goes through. I have removed the original photo and replaced it with two photos I shot within the last half hour of my cars.
da
Is there a difference between US and UK/Euro spec cars? da
Dan Aycock
Walla Walla, Wa.
Yellowhawk Valley Spitfires
Edited 1 time(s). Last edit at 2019-02-09 02:32 PM by Yellowhawk Valley.
20190209_115047.jpg    41.6 KB
20190209_115127.jpg    23.2 KB
mandmind Avatar
COCOA, FL, USA   USA
thanks all… I didn't think there was one when I took it apart but who knows... Fits better without one anyway...
I'll try anything
Mikey
In reply to # 1595442 by mandmind thanks all… I didn't think there was one when I took it apart but who knows... Fits better without one anyway...
Yes, it will not fit right with it in there.
This is one of several errors that occur throughout the many years of parts and repair manuals for the Spitfires that were never corrected. The most discussed is the upside down water valve for the heater.
da
Dan Aycock
Walla Walla, Wa.
1980 Triumph Spitfire 1500
