Installing body trim - last piece
chrisrintz Avatar
chrisrintz Gold Member Christopher Rintz
Winnetka, IL, USA   USA
I have successfully installed al but one ofl the body trim pieces using new clips. I really love this part of the job because everything feels like progress! Installing the final piece on the boot lid, and I can't seem to find a diagram that indicates which clips are appropriate for attaching this piece. I have bought into the argument that using adhesive increases the potential for damage if I ever need to remove, so I would prefer to use the clips if that is the correct method. I have a stash of all 3 different clips, so any advice is appreciated.
Spit body.pdf    147.6 KB
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
627362, but I never had any success with them and beat up my new paint, and the trim still isn't on there.
'S all for now
Vic
Falkon Avatar
Falkon Al Martin
Appleton, WI, USA   USA
My '73 came from the factory w/ a few clips, but also some sticky black goo.
chrisrintz Avatar
In reply to # 1602271 by Falkon My '73 came from the factory w/ a few clips, but also some sticky black goo.
Hmmm...when it came to cleaning up the strip for reinstallation, I did notice that there was some sort of caulk-like material in the grooves. I just figured it was the PO, and didn't give it a second thought until I started looking at the usual reference sources, and no clips are depicted.
vic - when i di the bottom strip those clips just slid on for me...the buggers for me were the tiny ones that hold one the fender strips.
1949 Triumph 2000 Roadster
1970 Triumph TR6
1978 Triumph GT6 "Scooter"
1978 Triumph Spitfire "Scooter"    & more
Christopher the ones for the longer strips are the wider ones, right around a 1 inch with the spacing in the middle. Install in the cover first.
A light tap with a rubber hammer should get it in place.
Sounds like you have the rest figured out.
+1 Yes No Thank
  chrisrintz thanked trrdster for this post
Mark Jones Avatar
Its retaining clip GHF1154
https://rimmerbros.com/Item--i-GHF1154
Capture.JPG    56.5 KB
+1 Yes No Thank
  chrisrintz thanked Mark Jones for this post
Falkon Avatar
Falkon Al Martin
In reply to # 1602290 by Mark Jones Its retaining clip GHF1154
Yes, that looks like what was in there.
+1 Yes No Thank
  chrisrintz thanked Falkon for this post
carChips Avatar
1933 MG Magnette
Chris, you circled the one for the boot lid, that's the only one I couldn't get to stay on. The wing trim uses smaller ones.
'S all for now
Vic
+1 Yes No Thank
  chrisrintz thanked carChips for this post
TheZster Avatar
TheZster Steven Z
SAINT LOUIS, MO, USA   USA
1978 Triumph 1500 "BLK-BRY"
Technology changes from 40 years ago..... Yes - original type clips do make sense...… But adhesives (such a multitude of options)… often work better than OEM..... Just a thought....
Z
The clips bite through the paint and primers and often cause rust under the trim strip.
For that reason 23-24 years ago I used 'Goop' adhesive to attatch that trim to the trunk lid.
+1 Yes No Thank
In reply to # 1602445 by Tonyfixit The clips bite through the paint and primers and often cause rust under the trim strip.
Tony,
Have you removed that trim since? With adhesives the test isn't whether you can make things stay on, it is whether they can be removed and re-installed. Some adhesives are the equivalent to welding the nut to the bolt to prevent loosening.
In reply to # 1602484 by spitfire50
Tony,
I have used the 'Goop' range of products (Shoe Goo, plumbers Goop, Automotive Goop ect.) in many applications. It is rather like silicone caulking, it has good adhesion yet will yield under steady mechanical pressure.
