Generally, how accurate is the alignment of the crank-pulley TDC mark alignment with the "0 degree" mark on the front cover scale?
I know how to determine TDC, but don't see any reason to do that if there is little benefit to the time spent.
How accurate is the crank-pulley TDC mark?
Posted by sdebaker
Vancouver, WA, USA
Feb 9, 2019 05:40 PM
Joined 12 years ago
Lizzard
d id
san jose, CA, USA
Feb 9, 2019 05:48 PM
Top Contributor
![]() ![]() Joined 6 years ago
The benefit is the answer to the question of putting in the time effort once .
Or
How can someone tell if its accurate sans doing the test ?
If you do the test 4 times for 4 cylinders you can have 2 , 3 or 4 marks . Iykwim .
Or
walla walla, WA, USA
![]() 1969 Triumph Spitfire "Walla Walla"
1969 Triumph Spitfire "Portland" 1972 Triumph Spitfire MkIV "Spokane" 1975 Triumph Spitfire 1500 "Dayton" & more |
Feb 9, 2019 06:26 PM
Top Contributor
![]() ![]() ![]() Joined 7 years ago
Generally it is right on.
da
Dan Aycock
Walla Walla, Wa.
Yellowhawk Valley Spitfires
da
Dan Aycock
Walla Walla, Wa.
Tonyfixit
Tony M
Duncan, BC, Canada
Feb 9, 2019 07:02 PM
Top Contributor
![]() ![]() ![]() ![]() ![]() Joined 2 years ago
After 40 + years, who knows?
The timing cover may have been changed, and in any case the front pully is small.
It is good enough to set ignition timing, which is kind of arbitrary anyway.
If timing a cam etc. You will use other means anyway.
SpiTazz72
Bryan H
Magnolia, TX, USA
Top Contributor
For spark timing it's close enough but for checking valve timing It depends on your timing chain and would be safer to use another method.
spitfire50
Paul Mugford
Rochester, N.H., USA
Feb 9, 2019 07:32 PM
Top Contributor
![]() ![]() ![]() ![]() ![]() Joined 8 years ago
Paul,
Even if most of them are dead accurate you don't know the one on your engine is good. Carefully checking it is the only way to know what is TDC.
Doug in Vegas
Douglas D
Las Vegas, NV, USA
Feb 9, 2019 11:36 PM
Top Contributor
tapkaJohnD
John Davies
Lancaster, Lancashire, UK
Feb 10, 2019 05:29 AM
Top Contributor
![]() Joined 5 years ago
Paul,
You don't say if you have a four or six-cylinder engine. This is an important factor, because of the difference between the front pullies on the two engines.
A four cylinder engine, Spitfire, Herald etc is a solid metal disc.
On a six, the disc has a separate ring on it, held in place by a rubber layer. This acts as a vibration damper, thought to be necessary for the longer cranked six, but not the four. The timing marks are engraved onto the outer surface of the outer ring.
Rubber loses its properties in the heat and hydrocarbon-filled environment of an engine bay, and sometimes it will lose adhesion, so that the outer ring moves on the inner hub, making the timing marks a complete fiction. It is difficult to tell, unless you find TDC by other means, as the outer surface of the rubber may become swollen, cracked and perished, but inside it still holds on. A failed damper pulley also fails in its damping task, and excess vibration and even crank failure can follow, due to resonance at certain speeds.
If you are concerned that your timing marks are incorrect through this mechanism, then find TDC by other means and compare. I'm researching crank damper pulley testing and have a prototype technique to do so, but as dampers are a heavy itme to post, I fear that it would cost you a lot to send me your damper for checking. Be glad to if you wish.
Dave at OldSchool
Dave Perry
Battleground, AL, USA
Feb 10, 2019 12:25 PM
Joined 2 years ago
consider it a reference point ONLY.........
Tony has it right " It is good enough to set ignition timing, which is kind of arbitrary anyway. "
Dave Perry OldSchool Restorations of North Alabama USA
Dave at OldSchool
Dave Perry
Feb 10, 2019 12:32 PM
Joined 2 years ago
Paul, the ONLY way to determine actual TDC is with a dial indicator, observing both the start and the end degrees of TDC and dividing the result by two, and of course it requires removing the head to do that (unless you have the tool setup to do it through a spark plug hole)
ExPatBrit
Mike W
Redmond, WA, USA
Feb 10, 2019 12:44 PM
Joined 6 years ago
The woodruff key that holds the pulley has been known to fracture, if you have timing shifting around it's worth a look.
clshore
Carter Shore
Beverly Hills, FL, USA
Feb 11, 2019 06:42 AM
Top Contributor
![]() ![]() ![]() ![]() ![]() Joined 7 years ago
In reply to # 1595571 by Dave at OldSchool
No dial indicator or head removal needed to find TDC, but a degree wheel is required.
The 'through the spark plug hole' style piston stops are dead cheap on eBay, and used properly, work very well..
That said, timing a cam DOES require a dial indicator, adequate kits can be had for under $25 USD.
Dave at OldSchool
Dave Perry
Feb 11, 2019 08:51 AM
Joined 2 years ago
Carter, "well " may be 'good enough' , but a stop does not give accurate enough results to be actual
Lizzard
d id
san jose, CA, USA
Feb 11, 2019 09:27 AM
Top Contributor
tapkaJohnD
John Davies
Feb 11, 2019 09:51 AM
Top Contributor
Dave,
Trying to find TDC with a dial gauge. The piston slows down and slows down, and finally stops rising. As you continue to turn it starts to go down again, after a wait around TDC due to tolerances in the bearings.
Where does it stop and start? Somewhere on the degree wheel, could be anywhere within that degree mark. It's a subjective judgement.
In contrast, if you set the piston stop in the middle of the stroke, it is moving as fast as it can for each degree of movement, and there is absoluely no doubt about where it stops. The measurement is objective.
Then simple arithmetic, divide the angle by 2 and you KNOW where is TDC.
JOhn
JOhn
Forums
Spitfire & GT6 ·
TR7 & TR8 ·
TR6 Tech ·
TR5 & TR250 ·
TR4 & TR4A ·
TR2 & TR3 ·
Buy, Sell & Trade ·
Vendor Market ·
Triumph Performance ·
Herald & Vitesse ·
Stag, 2500 & 2000 ·
Roadster & Pre-War ·
Odds & Ends ·
The Pub - Off Topic ·
List Archives ·
Motorsports ·
Meetup
