In reply to # 1595533 by Doug in Vegas
Do not rely on the Temp gauge.
They usually are wrong.
Well seeing as they are not calibrated. .........
But yes, they can be misleading.
I have spent some time trying to get to the bottom of this, the gauges themselves seem to be pretty reliable but there are other components the may cause readings that are not.... intuitive.
Both our Fuel and Temp gauges are powered through a voltage stabilizer. An electro mechanical device that may cause erroneous gauge readings. Also the sender units used read temps at the engine, may be inappropriate for their application.
The photo below shows the gauge readings of two differant sender units used on the same car on the same day.
Edited 1 time(s). Last edit at 2019-02-10 11:52 AM by Tonyfixit.
