Battery size - and I apologize to start off with
gfe05111952 Avatar
gfe05111952 George Earwaker
Falls Church, VA, USA   USA
Here's pics for you, Zster. I've got the battery turned around to accommodate a battery cut off switch mounted through the firewall to the passenger parcel shelf. It will fit the other way around as well. thumbs up
George
1967 Triumph GT6
1967 Triumph Spitfire4 Mk2
1968 Triumph Spitfire Mk3
100_4545.JPG    41.7 KB
100_4543.JPG    36.2 KB
100_4544.JPG    40.3 KB
TheZster Avatar
TheZster Steven Z
SAINT LOUIS, MO, USA   USA
1978 Triumph 1500 "BLK-BRY"
Perfect - Thanks....
Notice you're not using a hold down...….. any particular reason?
Z
Edited 1 time(s). Last edit at 2019-03-13 10:11 AM by TheZster.
It's a good practice to employ a terminal insulator on the 'hot' post with our cars.
The 'flip up' type are easy and inexpensive.
This is the result of a PO installing the battery with terminals forward and no insulator on the posts.
da
Dan Aycock
Walla Walla, Wa.
Yellowhawk Valley Spitfires
79 paint8.JPG    27.6 KB
sampattr250 Avatar
sampattr250 Sam P
Harwinton, CT, USA   USA
Z,
Napa lists both a group 24 & 34 in there Legend series:
8424 : CA @ 32F 890 CCA @0F 725
8434 : CA @ 32F 985?? CCA @0F 800.
Both technically fit in my 72 Spit, however the group 24 is taller and will not fit with a battery disconnect switch. I had to make two trips to my local NAPA
Sam
1968 TR250
1972 MK IV Spitfire
IMG_4179.JPG    31.2 KB
IMG_4180.JPG    51.2 KB
gfe05111952 Avatar
In reply to # 1601793 by TheZster Perfect - Thanks....
Z
New battery in Dec. & haven't gotten around to making one up. Those from our suppliers are too short, so a custom hold down is needed.
George
1967 Triumph GT6
