I still need help!
I took the top of the gearbox off...got the thing out of N...and into gear..put it all together and now it just seems to be stuck in 2 or 4...I cant tell...
any ideas?
71 spit. Stuck in nuteral. HELP
Posted by jameyemail
jameyemail
jamey winchester
portland, OR, USA
Feb 3, 2019 02:48 PM
Joined 6 years ago
Lizzard
d id
san jose, CA, USA
Feb 3, 2019 03:59 PM
Top Contributor
![]() ![]() Joined 5 years ago
In reply to # 1594075 by jameyemail
I still need help!
any ideas?
I can help you , but you have to do what I ask and not do what I don't ask . If you had done as I requested you would know if you were in 2nd or 4th .
any ideas?
Years ago I was promoted , I was put in charge of the techs , when they had a problem they could not understand / solve they were instructed to bring it to me , I would then tell them the first steps to take , I expected them to go back , do the steps and then report back . We would work on it together that way . They would learn and not have to request help as much in the future hopefully .
jameyemail
jamey winchester
portland, OR, USA
Feb 7, 2019 04:59 PM
Joined 6 years ago
Ok..i put the shifter rebuild kit in....got the covers back on...and still in 3rd or 4th...the 3 rcvrs for the shift fork eere all lined up when i put it together and the shift lever goes side to side..just not fore or aft. And cant get it int N that way
spitfire50
Paul Mugford
Rochester, N.H., USA
Feb 7, 2019 07:29 PM
Top Contributor
![]() ![]() ![]() ![]() ![]() Joined 8 years ago
In reply to # 1594944 by jameyemail
Jamey,
With the handbrake released could you push the car? Yes = in neutral. No = all shift forks have selected a gear.
jameyemail
jamey winchester
portland, OR, USA
Feb 7, 2019 07:37 PM
Joined 6 years ago
Lizzard
d id
san jose, CA, USA
Feb 7, 2019 08:04 PM
Top Contributor
Are you willing to do what I ask and then do nothing but what I ask ? If so I am willing to try and diagnose the problem from afar .
jameyemail
jamey winchester
portland, OR, USA
Feb 8, 2019 01:13 AM
Joined 6 years ago
Notti
Eric N
San Dimas, CA, USA
Feb 8, 2019 02:48 AM
Top Contributor
![]() Joined 4 years ago
You guys should either do this as a PM or email, even phone because there is a lot of re-direction by others trying to help.
Lizzard
d id
san jose, CA, USA
Feb 8, 2019 08:42 AM
Top Contributor
In reply to # 1595014 by jameyemail
sure..if possible
Divide and conquer/concur . The problem is in the box of gears or in the controls . I'm not sure if the problem is here or there so I'm going to separate the two things and test them separately .
1) I'd unbolt the top from the box . Then test the action of the shifter . Does the shifter go back and forth into and out of the 1 , 2 , 3 , 4 and R positions when its unbolted from the box .
2) With the top still unbolted from the box , will the gears (1 , 2 , 3 , 4 and R positions) be selectable ? Can you reach down into the gearbox and move the part/s to engage each gear ?
If it fails to shift into and out of gear position (1 , 2 , 3 , 4 and R positions) in test #1 we need to focus on that and not bother with test #2 .
If on the other hand it passes test #1 then we go on to test #2 .
Please don't start up the motor yet .
If anything is unclear in what I'm saying , ask question before proceeding .
jameyemail
jamey winchester
portland, OR, USA
Feb 8, 2019 08:58 AM
Joined 6 years ago
I put a new shifter bushing kit in yesterday. The shifter moves freely.
Once i bolted back on...it wouldnt move.
Lizzard
d id
san jose, CA, USA
Feb 8, 2019 09:46 AM
Top Contributor
In reply to # 1595046 by jameyemail
Was that "The shifter moves freely." with everything till the gear box attached ? Was that , shifter , shift extension , gear box top , three shift rods and forks , all moving as they should ?
Lizzard
d id
san jose, CA, USA
Feb 8, 2019 09:50 AM
Top Contributor
In reply to # 1595018 by Notti
I prefer to do this openly , if I make a mistuke someone no doubt will catch it , if someone else gleans something that's a good thing also .
jameyemail
jamey winchester
portland, OR, USA
Feb 8, 2019 01:21 PM
Joined 6 years ago
I am headed across town chill where's my car is. I will pull off the cover to the top of the gearbox and make sure that the shifter and all those mechanisms all work. I will let you know soon.
Lizzard
d id
san jose, CA, USA
Feb 8, 2019 03:05 PM
Top Contributor
jameyemail
jamey winchester
portland, OR, USA
Feb 8, 2019 03:19 PM
Joined 6 years ago
It is in the shifter linkage. Too much slop in the connection in the middle.
I saw on one of these threads about the gearbox being in N when reassembling the top with the forks onto the gears.?
And if that is the case...how do i get it into N without the shifter?
Forums
Spitfire & GT6 ·
TR7 & TR8 ·
TR6 Tech ·
TR5 & TR250 ·
TR4 & TR4A ·
TR2 & TR3 ·
Triumph Performance ·
Buy, Sell & Trade ·
Vendor Market ·
Herald & Vitesse ·
Stag, 2500 & 2000 ·
Roadster & Pre-War ·
Odds & Ends ·
The Pub - Off Topic ·
List Archives ·
Motorsports ·
Meetup
