71 spit. Stuck in nuteral. HELP
jameyemail Avatar
jameyemail jamey winchester
portland, OR, USA   USA
Hey Everyone...
Got a 71 Spitfire with a 4-speed. Yesterday it I couldn't get it into reverse. I know I need a shift kit. But was able to drive the thing to work. I get to work and I go to leave at lunch and I don't have 1st gear 2nd gear or anything. Pulled the Shroud and all that I took the cover off and to look inside and I'm not really sure what it's supposed to look like looking down into the hole. I see where the little shift lever little thing on the ball goes into the tranny and the gearbox. And it's a three rail should get the three little detent things. And I believe it's the reverse on the right hand side when you're looking down there? The clutch feels fine. But it won't go in gear it won't move at all. Help
Lizzard d id
san jose, CA, USA   USA
Is the shift lever floppy ?
jameyemail Avatar
Yes...and i understand that part. New shifter kit..With the top cover off the gearbox...i cant move it into gear.
Is the clutch working?
Lizzard d id
You took the cover off of the transmission and are looking down into the gears / oil ?
jameyemail Avatar
I believe so..it isnt engaging into gear..and the clutch feels normal.
jameyemail Avatar
Yes...i cant really see any oil....but when i start it i can see some sloshing looking forward.
Smithisretired Avatar
Smithisretired Michael Smith
Wells, ME, USA   USA
Need clarification on "can't get it into gear." Will it go into any or all gears when the engine is not running? Or does the problem occur only when the engine is running (that is, when you try and shift into first or reverse, or other gears, is there a clashing of gears that prevents the shift?)?
jameyemail Avatar
Running and non running ..
Wont shift into gear
jameyemail Avatar
It just usnt moving the selector inside the gearbox...
rammy Avatar
rammy Mark W
Ashland City, TN, USA   USA
1973 Triumph Spitfire 1500 "Jasmine"
if you can take some pictures of what your looking at, that would help in narrowing down what you are seeing and what everyone else is seeing in their heads
Put it in 4th and bump it no clutch to see if it catches.
Oh, chock the wheels first.
(Hoping you read this before a Bueller.)
jameyemail Avatar
It doesnt go into gear..i should be able to move the rods without reinstalling the shift mech....right?
In reply to # 1593611 by jameyemail It doesnt go into gear..i should be able to move the rods without reinstalling the shift mech....right?
I have a single rail so I'm not much help.
I know 4th is 1:1 so the hope is to link input and output.
1966 Triumph Spitfire MkII
