Odds & Ends Forum
What is this?
What is this?
  This topic is about my 1976 Triumph Spitfire 1500
McGuire Avatar
McGuire Silver Member Matthew McGuire
Arlington, VA, USA   USA
I found an odd cable poking out from under the cockpit into the engine bay.
Does anyone know what this or was?
Matthew
image.jpg    50.3 KB
grubscrew Avatar
grubscrew grub screw
where does the other end go?
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
McGuire Avatar
Not sure yet. I haven't had time to trace where it leads. Was hoping someone might recognize it.
Matthew
Fictioneer Avatar
Fictioneer Doug Hirt
An old, broken speedometer cable no one bothered to remove after replacing it?
McGuire Avatar
Thanks Doug. I think you might be onto something. The PO seems to have done some odd things with the lights, wires, and cables behind the dash. I need to follow it and see where it ends.
Matthew
If that is coming out onto the passenger (right) side outrigger, I am guessing it is the shield for the fuel tank vent line, that is no longer there. If so, it will run back to where the line would have come down through the boot floor and headed to the front/
Heavenly Acres John Claybaugh
Texico, IL, USA   USA
Maybe left over trip-ometer cable. mine mounts under dash by steering column.
It's the tin worm we all hear about.
gfe05111952 Avatar
gfe05111952 George Earwaker
Falls Church, VA, USA   USA
In reply to # 1318574 by Fictioneer An old, broken speedometer cable no one bothered to remove after replacing it?
+1
It's on the right side & right place. Does your speedometer work?
George
1967 Triumph GT6
1967 Triumph Spitfire4 Mk2
1968 Triumph Spitfire Mk3
byakk0 Avatar
byakk0 Hazen Wardle
Boise, ID, USA   USA
Bottle it and keep it away from your car, don't let it get wet, and never feed it after midnight. grinning smiley
In reply to # 1365355 by Doug in Vegas It's the tin worm we all hear about.
~Hazen.
Limey Midget Man Avatar
Limey Midget Man John McGuire
Raytown (Kansas City), MO, USA   USA
1975 MG Midget 1500 "Liberty"
1979 Triumph Spitfire 1500 "Justice"
Hello Mr. McGuire. John McGuire here... I just went to the garage to see if my fuel return line / vent line traced the same path (over the RF outrigger). That's what it is. From the stub that you see, it goes forward to the carbon canister (the front one on 2-cannister systems). I attached a photo that I took a few months ago in the showroom of Victoria British. There's a restored '79 on their showroom floor next to the parts counter. I live 20 minutes away. Take care my friend.
VB 79 Spit return line.jpg    43.1 KB
1980 Triumph TR7 Drophead
