Odds & Ends Forum
1978 spitfire ignition with key needed
mtptriumphjr Avatar
mtptriumphjr David Wyatt V
Mount Pleasant, ON, Canada   CAN
my poor car wont stay running unless I hold the key forward a bit, need to find a replacement so I don't have to go with a toggle switch and a push button starter.
Greasy Paul Avatar
Greasy Paul Paul Donnell
Bend, OR, USA   USA
Since it doesn't work anyway you could try taking the switch apart and clean the contacts.
Mine needed to be removed, cleaned and then epoxied back together.
corillion Avatar
corillion Cherie Orillion
Covington, LA, USA   USA
1976 Triumph Spitfire 1500 "Tin Lizzy"
I think I can have my old one. Will check this weekend
1970 Triumph Spitfire MkIII
