Painting my Spitfire
redcoat79 Avatar
redcoat79 Ron J
Olathe, Kansas, USA   USA
A big helper to eliminate dirt is wet the floor or ground before you get started. Made a huge difference for me.
grubscrew Avatar
grubscrew grub screw
Local high school collision repair tech center.
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
Jim Conaty Avatar
Swampscott, Massachusettes, USA   USA
1973 Triumph Spitfire 1500 "Bumblebee"
My first time painting. In my driveway with the Eastwood Concours spray gun, single stage urathane paint from TCP Global Restoration. I sprayed metallic, if I had to do it again I would spray solid.
Jim
blue3.jpg    35 KB
wilson7136 Avatar
wilson7136 Curtis Wilson
Archdale, NC, USA   USA
Maaco actually did a good job on the paint. $600 with a primer, base and clear coat. I wished I had spent about another year on the bodywork. Mine had been resprayed at least twice over the factory paint. Took most of the summer to get to bare metal. Every defect telegraphed through the paint. Looks good at 10 feet or 10 mph, whichever comes first.
Curtis
new paint.jpg    39.3 KB
wildwood Avatar
wildwood Rick Howe
Wayne, NJ, USA   USA
Mike you can do it ; i used the roll-on method which is a lot of work but i couldn't spray no garage and neighbors homes wouldn't want the paint drifting on to their homes but the roll-on was very cheap to do just a lot of sanding . Before and after.
IMG_0093.JPG    55.6 KB
IMG_0106.JPG    60.6 KB
IMG_0107.JPG    42.7 KB
IMG_0016.JPG    75.8 KB
Andy-Sherry Avatar
Portland, OR, USA   USA
Sherry's is PPG Base Coat Clear coat and with some help it was done in a garage,driveway and backyard,go for it.
My best tip is you cant do enough prep
Andy&Sherry
1974 Spit 1500 Carmine Red
Always learning something
pink sptfire.jpg    73.1 KB
claytoncnc Avatar
Our old Daimlers were painted at home, won some concours events.
My dad's projects, not quite my cup of tea
Special Sports 1.jpg    46.8 KB
Special Sports 4.jpg    49.3 KB
DB18 Before 2.jpg    48.2 KB
DB18 After 2.jpg    43 KB
claytoncnc Avatar
Painting and restoring my sister's old Herald in the shed, My sister in law, Kumi on the first ride, and arriving in Adelaide (1000km) for the Bay to Birdwood rally.
All done at home. My brother has a nice shed.
DSCF00160.JPG    42.1 KB
DSCF000555.JPG    44.4 KB
DSCF913.JPG    37.5 KB
Herald20070929_23.JPG    66.6 KB
wildwood Avatar
wildwood Rick Howe
Wayne, NJ, USA   USA
thats one hell of a shed it could be a warehouse eye popping smiley
Chainsaw Avatar
Chainsaw Mike Conners
Brentwood, Brentwood, Tennessee, USA   USA
I like your paint booth. I'm also looking at Inca Yellow. I don't know if you noticed in the picture or not, but I powered coated my valve cover in that color and I really like it.
Chainsaw Avatar
WOW! your car looks great.
Chainsaw Avatar
Ok, I'm going for it. I'm going to bring the body back from my storage bin in the next couple of weeks and get started on prepping. Thanks again to everyone for your encouragement. I will keep you posted.
tinks-dad Avatar
tinks-dad Silver Member Bob C
Newburgh, NY, USA   USA
I've found the Auto Body 101 forums contain a lot of great info. As Andy mentioned, prep is everything. Start on the floor pans or some other out of sight panels until you get into a routine.
Good luck.
Pats54 Avatar
Pats54 Gold Member Mark M
Maynard, Mass, USA   USA
1979 Triumph Spitfire 1500
In reply to # 924764 by wildwood Mike you can do it ; i used the roll-on method which is a lot of work but i couldn't spray no garage and neighbors homes wouldn't want the paint drifting on to their homes but the roll-on was very cheap to do just a lot of sanding . Before and after.
Rick what is the roll on method ? You applied auto paint with a roller
I never knew there was such a method
wildwood Avatar
wildwood Rick Howe
Wayne, NJ, USA   USA
Mark you are right i used high density foam rollers and rustoleum paint you can see how to do this type of paint job at www.rolledon.forummotion.com or you can go on you tube rick.
