Sway Bar Link
OldBlue Avatar
OldBlue Doug Johns
Elyria, OH, USA   USA
1970 MG MGB "Colonel Mustard"
MAN, this sounds like a REALLY dumb question for such a simple part, but here goes.....
Can someone tell me if the stud coming out of the sway bar link that bolts to the lower control arm is supposed to be tight in the link or should it spin? Referring to the picture below, "A" is the top of the link and if "B" is supposed to spin, how in the name of whoever the hell you worship are you supposed to hold it to tighten down the nut "C" (with a wrench around it)? With the way they made the mount in the lower control arm "D", it's impossible to hold the stud to tighten the nut down.
Boy I feel dumb...
Doug
Edited 1 time(s). Last edit at 2013-10-29 10:37 AM by OldBlue.
IMG_0114.jpg    45.1 KB
ExPatBrit Avatar
ExPatBrit Mike W
Redmond, WA, USA   USA
Big screwdriver wedged in gap between the link and the arm worked for me!
spaceguinness Avatar
spaceguinness Michael Nelsen
Austin, TX, USA   USA
+1 on big screwdriver
spitlist Avatar
spitlist Joe Curry
Ideally, it would be nice for the frame to hold the thing in place but we all know that these things seem to rarely be ideal.
Joe
Edited 2 time(s). Last edit at 2013-10-29 12:46 PM by spitlist.
OldBlue Avatar
OldBlue Doug Johns
Elyria, OH, USA   USA
Thanks guys.
Doug
byakk0 Avatar
byakk0 Hazen Wardle
Boise, ID, USA   USA
I shoulda thought of the screwdriver.angry smiley I was fighting one to get it apart. I managed in the end with a box-end wrench skewed at a funny angle. Hindsight says a screwdriver would have shortened the job and frustration. Guess I'll use that as a re-assembly technique.
~Hazen.
Pats54 Avatar
Pats54 Gold Member Mark M
Maynard, Mass, USA   USA
1979 Triumph Spitfire 1500
More info on the sway bar would help. This is one of the items I need to replace, still looking for the answer on the bolt
"A" should it spin or not?
Thanks guys
ExPatBrit Avatar
ExPatBrit Mike W
In reply to # 922122 by Pats54 More info on the sway bar would help. This is one of the items I need to replace, still looking for the answer on the bolt
Thanks guys
It's doesn't spin but a brand new one is loose, it moves but not easily.
Austin, TX, USA   USA
Mine spins, but it is original, so it's old. I was also able to use a 6in adjustable crescent wrench to get a bite on it enough to remove it.
OldBlue Avatar
OldBlue Doug Johns
Elyria, OH, USA   USA
I learned a lot about the link over the last 2 days! Yes, it will spin, but not easily - it is mounted in rubber, but there is not a metal-to-metal connection. They will/do wear over time, since it's a rubber "ball" with a metal stud pressed into it.
Oh, and BTW, the jam-a-big-screwdriver-in-there technique works well! grinning smiley
Doug
Edited 1 time(s). Last edit at 2013-10-30 12:31 PM by OldBlue.
1972 Triumph Spitfire MkIV
