Throttle linkage for twin SU?
74Spit Avatar
74Spit Rick Ladd
Brooklyn, New York, USA   USA
Interested in purchasing the proper throttle linkage for twin SU Carbs, new or old. Does anyone know who sells them? Anyone have a good photo to post of what it should look like? Thanks!
. Hide banner ads & support this website by becoming a > Supporting Member <
OFRacer Avatar
OFRacer Mike H
Poughkeepsie, NY, USA   USA
From your sign on, I'm assuming you have a 1500 and want to convert from the single Stromberg carb to the British spec HS4s or a pair of HS2s from a MKIII. Rimmer Bros, in England, has the parts for these conversions, I've done both. They also have exploded diagrams detailing the parts for each setup. I also rigged one up with some aluminum angle bracket and general purpose throttle return springs on my 1296 engine.
Rimmer Bros - Fuel Systems
My homemade bracket
mike
74Spit Avatar
74Spit Rick Ladd
Thanks Mike. Very helpful!
mkivmarty Avatar
mkivmarty Marty Yanik
N.E.Ohio, USA   USA
I had the same dilemma when I mounted the SUs; missing linkage. I hacked the piece from an old ZS carb to hold the throttle cable and mounted it to the plate that holds the return springs. Its worked great for three years.
Marty
Carbs.jpg    43.2 KB
74Spit Avatar
74Spit Rick Ladd
Hey Mike, Can you please explain what you did with all the extra oil lines? Looks very interesting.
Thanks for the info Marty1
rhodyspit75 Avatar
rhodyspit75 Ernie Connor
Cumberland, RI, USA   USA
Here's mine the first is the linkage that came with the set and the second is what I made.
Ernie
1975 Triumph Spitfire
image.jpg    44 KB
image.jpg    56.2 KB
74Spit Avatar
74Spit Rick Ladd
Very nice Ernie. Your hand made linkage is what got me thinking about a better set up. Thanks!
68spitmk3 Avatar
68spitmk3 jim dordan
niles, ca, USA   USA
nice looking set up, i wish mine was that clean, well it the front seal did not leak and spray oil then i think it would look nice since i drive it every day then i can deal with it, enjoy.
OFRacer Avatar
OFRacer Mike H
The picture is from my 63 Spitfire race car. I added an external oil filter and cooler. The large braided hose running back along the firewall goes to a 2 quart Accusump mounted in the cockpit.
mike
Edited 1 time(s). Last edit at 2013-03-24 10:06 AM by OFRacer.
spurs1canada Avatar
spurs1canada Silver Member Barry Hotspur
Winnipeg, Manitoba, Canada   CAN
1972 Triumph GT6 MkIII "Mellow Yellow"
1976 Triumph Spitfire 1500 "Li'l Red"
Anyone got a pic of an installed HIF4 ?
tinks-dad Avatar
tinks-dad Silver Member Bob C
Newburgh, NY, USA   USA
Still a work in progress... 1980 1500 w/1979 HS4 carbs.
Bob
HS4s.jpg    42.6 KB
gadams Gerry Adams
Lincoln, Nebraska, USA   USA
Waking the old
I am unhappy with the throttle response due to the play in the linkage with twin SUs.
The throttle linkage appears OEM.
The photos show the slack, one resting, the other lifted to first response-- all that travel is unresponsive
Gerry
image.jpg    37.3 KB
image.jpg    41.6 KB
74Spit Avatar
74Spit Rick Ladd
The location of the spring is wrong. Mine is set up as return spring keeping the cable firm. Best to look up the correct set up.
gadams Gerry Adams
Rich
Thanks. The spring isn't the problem tho.
The pivoting movement costs some 2" of petal push (based on sensation) and nothing accelerates, then at the high acceleration end i think the cable has run out of pull-length. I'm missing top end acceleration potential because travel is limited by maximum cable movement (which has lost 2" already)
74Spit Avatar
74Spit Rick Ladd
Is your cable to long? Mine was and I cut the end and threaded a locking end from a bike shop. I still do not understand the purpose of the placement of your spring.
1970 Triumph Spitfire MkIII
