1500 crankshaft pulley?
spurs1canada Avatar
spurs1canada Silver Member Barry Hotspur
Winnipeg, MB, Canada   CAN
1972 Triumph GT6 MkIII "Mellow Yellow"
1976 Triumph Spitfire 1500 "Li'l Red"
I'm in the process of getting all the parts together for rebuild of my spare block (parts are in getting cleaned and tested).Problem is the pulley is broken and VB and Moss don't have them,VB has one for the MKiv up to 1972 mine is 1976 will that fit? pricey too $95.
rhodyspit75 Avatar
rhodyspit75 Ernie Connor
Cumberland, RI, USA   USA
spurs1canada Avatar
cheers but is that a crack at the bottom right?
RPJ Avatar
RPJ Rick J
Santa Fe, NM, USA   USA
I think Rimmer Bros carries them new (don't ask how I know this).
spurs1canada Avatar
Holy crap $199 at Spitbits and it says Mk4/1500 so i guess VB at $95 is a deal and MK4 will fit by the look of it.
rhodyspit75 Avatar
When I blow up the pic, it does look like something is wrong. I would talk to them first.
Ernie
1975 Triumph Spitfire
mkivmarty Avatar
mkivmarty Marty Yanik
N.E.Ohio, USA   USA
What year did the 1500 get the airpump, and the 2nd belt slot on the pulley? If you're not running the pump the MKIV pulley may fit your crank.
Marty
spurs1canada Avatar
It is a single pulley.
Mark Jones Avatar
1995 MG MGF "Barney"
1996 Land Rover Discovery
Barry, call Obsolete Auto, http://www.obsoleteauto.com/, 1-800-265-7437. They have a lot of used parts.
1976 Triumph TR6
