Installing Electric fan
Marc69MK3 Marcos Rodriguez
NJ, USA   USA
1969 Triumph Spitfire MkIII "Darla ( From The Little Rascal"
Guys I am installing an Electric Fan for the radiator do you think this combination will work, so that the fan only comes on when the car is on or engine is engaged
I want to have a relay and a fuse in the mix
Edited 2 time(s). Last edit at 2012-01-13 07:14 PM by Marc69MK3.
untitled electrical.JPG    10.9 KB
Falkon Avatar
Falkon Al Martin
Appleton, WI, USA   USA
You want direct "heavy duty" battery power to #87 and then on to the fan from #30. You want to trip the relay w/ ign power tp terminal #85 Fuse right at the battery for fan load.
NJ, USA   USA
Like this you mean
Copy 1of untitled electrical.JPG    10.9 KB
Saxist Avatar
Saxist Silver Member Dave B
Valleyfield QC, Canada   CAN
Marcos with this setup the fan runs all the time the key is on. I would suggest a setup with a thermostat switch that turns the fan on only when its needed like at idle in traffic or maybe climbing a hill. Just another idea here is the diagram and you can purchase these switches on ebay or places like summit.
Edited 1 time(s). Last edit at 2012-01-13 07:59 PM by Saxist.
efaninstall2.gif    4.1 KB
spitlist Avatar
spitlist Joe Curry
Here's my take on such a project.
You can add a fuse between the positive fan contact and the output of the relay. Make sure it is large enough to handle the poewr draw of the fan.
The bypass switch lets you turn on the fan manually if the thermostat fails.
Joe
Edited 3 time(s). Last edit at 2012-01-13 07:49 PM by spitlist.
Electric Fan wiring.JPG    4.5 KB
NJ, USA   USA
One quick question is it bad to have the fan all the time on ?
Also if I do your setup or Joes then I would need something like a probe to alert the fan of the temp ? correct and I have no clue what to get and where aside from the internet sad smiley wnted to get thisover with tonight or tomorrow, dont ask me why the rush maybe 2012thumbs up smileydrinking smiley and want to get it done and at least drive it before the end of the world
If not I have to go with all the time ON
Edited 2 time(s). Last edit at 2012-01-13 07:58 PM by Marc69MK3.
Hi,
I also have a pilot light in parallel with the fan motor. That way I know that it is turned on whether thermostatically or manually.
Good luck,
Saxist Avatar
Most of those thermostat switches are adjustable so you can set the temp threshold to your liking. I have wired up some that continue to run even after the engine is off until the temp drops.
spitlist Avatar
spitlist Joe Curry
In reply to # 720240 by spitfire50 Hi,
Good luck,
me too. One thing about those lights is when the fan is off but air going through the fan is spinning the blades, it makes the fan act like a generator making the light flicker a bit with the generation of electricity.
Joe
grubscrew Avatar
grubscrew grub screw
I assume you want to do this for what everybody seems to think is some fantastic horsepower gain?
If that's your reason, then you need to understand that the only time you see a horsepower gain that amounts to anything is when the fan isn't running, so yes, you want it to shut off (and come on) in response to temperature. So that's why you include a thermostat.
Otherwise, you'll be switching it on and off manually as you try to watch, and keep up with, the always-suspect temperature gauge on the dashboard.
Joe's set up that provides for both thermostatically controlled, and manual override, is the best.
Dave
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
Saxist Avatar
I don't think its bad to have the fan on all the time but they do draw allot of power and might even dim your lights. For just a little more money you can do it up real nice ... here is a link for a kit or just look at some of the others on ebay http://www.ebay.ca/itm/185-DEGREE-FAN-THERMOSTAT-TEMPERATURE-SWITCH-RELAY-KIT-/400214167002?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d2e9f8dda
Edited 1 time(s). Last edit at 2012-01-13 08:08 PM by Saxist.
Saxist Avatar
yup exactly grub not allot of gain ...the only reason I might do it is I hate the cost of clutch fan replacements....
Falkon Avatar
Falkon Al Martin
Joe's setup is the BEST one. The idea of an override switch is a good idea. i don't think you'd want to wire it to run w/ the engine off in a Spitfire. Too much draw on a small electrical system. Then again our wiring isn't that great either. Safer off w/ the key off.
racer490 Jerry Bryant
Palm Harbor, USA   USA
On my 80 the idle drops a little when the fan comes on haven't quite figured that one out. Does the fan draw so much power it effects the spark?
Bodge Garage Avatar
Bodge Garage Kris Schmidt
Spokane WA, USA   USA
In reply to # 720252 by racer490 On my 80 the idle drops a little when the fan comes on haven't quite figured that one out. Does the fan draw so much power it effects the spark?
The power demand puts a load against the alternator. More load means more power needed, at idle your torque is low thus slowingthe RPM
1972 Triumph GT6 MkIII
