Dual HS2 vs dual HS4 for 1500
oldag98 Avatar
oldag98 Jeff and Brittany Brackenridge
Choctaw, Choctaw, Oklahoma, USA   USA
1969 MG Midget MkIII
1975 MG Midget Conversion
1976 MG Midget 1500 "Yellow One"
1977 MG Midget 1500 "Dunkirk"    & more
Does the US 1500 really need dual HS4's, or will the dual HS2's from a 1300 be sufficient for a slightly hotter street car? I have both on my 1500 Midgets, but don't really see much difference in performance between the two. If you look at the stock ZS, I can't really see where it would flow more air or fuel than the dual HS2's. This makes me think that maybe the dual HS4's might be overkill on the 1500. Even with a hotter cam and headers, I can't see where a set of 1300 HS2's with non-poppet valved butterflies, K&N filters, and maybe richer needles and softer springs would not be able to keep up with the induction requirements of the 1500. What are your thoughts?
. Hide banner ads & support this website by becoming a > Supporting Member <
Midhurst80 Avatar
Midhurst80 Gold Member Bob Killam
Midhurst, Ontario, Canada   CAN
I have the dual HS2 carbs on a 1500 and have found them give all the punch the little engine can deliver. Turning up the power and RPM on the 1500 is more than the design can handle. If you want to move way up go get a the older engine as a start.
Jeff,
You are probably right, but you would more likely need stronger springs to keep the carb pistons from going wide open before the engine needs the full air flow the carbs can give. Classic Motorsports magazine ran a great article on the subject this year which can give you a feel for how little is lost using the smaller option. The big gain most people get when changing carbs comes from having new carbs not from having bigger carbs.
Good luck,
90632D Avatar
90632D Fox Trapper
Various, USA   USA
A whole lot of folk, myself included, have had quite good results running a pair of HS2's on a 1500 engine.
The HS4's only exceed the HS2's at high rpms. Something a 1500 is rarely going to see, especially one that does not live on a track.
wildwood Avatar
wildwood Rick Howe
Wayne, NJ, USA   USA
So then wouldn't a single HS6 work just as well as a pair of HS2 if then the manifold is opened up to match the carb and get more air flow ?
90632D Avatar
90632D Fox Trapper
Various, USA   USA
I've never actually installed it, but my understanding from those who have is the HS6 single works quite well on the 1500, up to something around 4,000 - 5,000 rpm.
trzavie Avatar
trzavie Al S.
Vast, Midwest, USA   USA
I have had both the HS2 with K&N's and the HS4's on my car over the years. There is not
all that much difference between the the two in normal driving. Both are way ahead of
the Stromberg. My HS2's were the kind used on the MK 3 with the PVC valve. Many years ago I had to
sort out an issue with my HS4's so a good friend loaned me the HS2 set until I
figured out that it was my waxstat jets causing the trouble with my HS4's. I'm not sure
what needles were on the HS2's, most likely not the proper ones for the K&N's! I put
my HS4's back on and over 20 years later I'm still happy with them. Recently my friend
moved south to retire and I aquired the HS2 set (amoung other parts) from him. One day
I will see which needles were on those carbs. If I had my choice on the HS2's I would
pick the MK 4 HS2's with the crankcase venting right into the body of the carb like
the HS4's have. Best of luck which ever you choose.
1974 Triumph Spitfire 1500
oldag98 Avatar
So the concensus seems to be that the HS2's will work fine on a road going 1500. If anyone has a differing opinion, please post and let me know why. Also, why then did BL use the HS4's on the 1500, instead of sticking with the HS2's from the 1300?
Spitnut64 Avatar
Spitnut64 Gold Member John Mills
Milwaukee, WI, USA   USA
1970 Triumph Spitfire MkIII "Sarah Jane"
In reply to a post by oldag98 Also, why then did BL use the HS4's on the 1500, instead of sticking with the HS2's from the 1300?
OK I'm speculating here but given what has been said - that HS4's only shine at the higher RPM's where most Spitfires don't live - could Triumph have had in mind better highway performance for non-overdrive Spitfires?
90632D Avatar
90632D Fox Trapper
Various, USA   USA
The HS2 work quite well on a track going 1500 as well. Just the HS4's will work better at the top end.
The 1500 is not incapable of spinning up. It does. It solidly can go into the RPM range where the HS4's give better performance than the HS2's. I would speculate that BL chose to let the engine have the breathing capacity to make the better power.
Just as a V8 can run fine on a 500 cfm 2-barrel carburetor, but can make a bit more power with a 750 cfm 4-barrel carburetor.
wildwood Avatar
wildwood Rick Howe
Wayne, NJ, USA   USA
A+ Foxthumbs up smiley
spitlist Joe Curry
Having previously run HS2's on a 1500 engine that was modified to increase the compression ratio, I can safely say that unless you radically modify the engine, to include radical cam, and much better breathing, the HS2's are sufficient. It is when you really start putting a real demand for increased fuel that they start to be deficient.
Joe
Edited 1 time(s). Last edit at 2011-12-14 10:46 AM by spitlist.
ras111 Avatar
ras111 Gold Member Richard Singerman
Dollard des Ormeaux, Quebec, Canada   CAN
Adding my 2 cents: My 1976 Spitfire actually originally had a HIF6 which I changed out for a Weber DGV. The Weber was far better at the low end but really lacked at the high end. I moved to dual HS4s this year and will never look back! Can't really comment on the difference between HS2 and HS4.....but do suggest you try different needles - really made HUGE difference for me on the HS4s. Looking back, the HIF6 actually worked very well too! Good luck.
oldag98 Avatar
OK, those running the dual HS2's and HS4's, what needles and springs do you have in them?
chappy444 Avatar
chappy444 Bill Chapman
Bel Air, MD, USA   USA
1975 Triumph 1500 "The Little Red Car"
I switched from the Weber DGV to the HS4's very happy i did it.
i am running ABT needles now...
~B
1979 Triumph Spitfire 1500
