SpitMan Avatar
SpitMan Doug Walls
Brandywine, Maryland, USA   USA
2007 Chevrolet Silverado
Thanks Dan. The stiffness of the poly may be a latching problem as you explained. For 5 more dollars US I think I will order the original type.
Doug-in-Vegas, I believe I got them from my favorite place Rimmer Bros.. They list the original type and the poly. First problem I have had with their stuff.
Doug, you got Jim back in your area after a 2700 mile trip and a couple of days here. Great fun and got a few things done. Hope he puts a long write up on his travels, I bet he gained 10 pounds. They band us from the Chinese Buffet between him and my wife.
Las Vegas, Nevada, USA   USA
In reply to # 1477554 by SpitMan Thanks Dan. The stiffness of the poly may be a latching problem as you explained. For 5 more dollars US I think I will order the original type.
The DPO of my car had put rubber from cane tips on mine.
The locating pins are $2.00 right now at TRF. They are the rubber ones. The last ones I got there are very good, still work perfect.
scardini1 Avatar
Great Mills, MD, USA   USA
1968 Triumph GT6 "Rocinante"
2003 Jaguar XKR "Kitty"
Haha,... Yeh the Chinese place will think twice before letting us do the all-you-can-eat thing again.
And the trip's apparently not over yet. I'm on the Chesapeake helping a friend with his boat!
I really need to get back to work so I can rest.
angel221 Avatar
angel221 Angel M
Cleveland, Ohio, USA   USA
Replaced the Starter. Pinion not sliding. What a joy to not hear it just spinning. 38 years of service is not to bad. I wish they were made better. HAHAHA
J.P.Rap Avatar
J.P.Rap J.P. Rap
Mount Hope, Ontario, Canada   CAN
1976 Triumph 1500 "Donna"
2007 Ford Ranger
Checked the oil then went for a drive. One of those days I just couldn't be in the house. Too many memories haunting me so I headed down to Port Dover and hung out on the beach for a while, bought another hat then headed back taking a few detours along the way. Perfect top down driving weather. 24° and just a few clouds. Nice.thumbs up
FrankD Avatar
FrankD Frank D
Doylestown, PA, USA   USA
Nice work J.P. !
Quote: Replaced the Starter. Pinion not sliding. What a joy to not hear it just spinning. 38 years of service is not to bad. I wish they were made better. HAHAHA
Did you try just cleaning the sliding shaft area to see if that would allow it to work or was it just dead?
Azoth Shane G
Los Angeles, CA, USA   USA
Worked on rebuilding my differential today - installed new oil seals on inner axle shafts as well as new bearings. Drove out the old bearing races for the pinion when I discovered that my brand new bearing has a defect on its race, so I had to stop for the day. Won't be able to get a new bearing race until monday. I've had these parts sitting in the garage for over a year so I don't know if it's worth the hassle to talk with spitbits about it - in the meantime I found the same bearing race on amazon.
SpitMan Avatar
SpitMan Doug Walls
Did he fit in "Rocinante"! Well he is skinny enough to carry an extra 10 lbs. LOL!
In reply to # 1477613 by trrdster Doug, you got Jim back in your area after a 2700 mile trip and a couple of days here. Great fun and got a few things done. Hope he puts a long write up on his travels, I bet he gained 10 pounds. They band us from the Chinese Buffet between him and my wife.
J.P.Rap Avatar
J.P.Rap J.P. Rap
2007 Ford Ranger
Today I found out my ignition has an "accessory" position. I didn't know that.
Also made a heat shield for the exhaust manifold. Just need to pick up some bolts for it tomorrow.
In reply to # 1477814 by J.P.Rap Today I found out my ignition has an "accessory" position. I didn't know that.
Actually, it's the radio position. A single white wire with a pink tracer. I like the idea of giving it it's own spot on the fusebox.
J.P.Rap Avatar
J.P.Rap J.P. Rap
2007 Ford Ranger
In reply to # 1477816 by Doug in Vegas
Yes. Now that you mention it, the radio is the only thing that operates in that position. I have an inline fuse at the radio.
Ive been contemplating putting in an ignition cut off switch so I could turn on the radio and not have power to the ignition. I wasn't too crazy about doing that and now I don't have to. I found it by accident while tracing a brake light problem. I thought it was strange that the brake lights only work when the ignition is on. Ive never seen that before.
angel221 Avatar
angel221 Angel M
@ Dan, I did check it and its clean it. But alas i think it is dead. Only slides part ways up on the shaft after i release it from its engagement position. I will over the winter replace the pinion gear and see what happens. Rimmer has that item in stock.
