Limited Slip Diff
96DXCivic Robert Coates
Huntsville, AL, USA   USA
Where can I find a limited slip differential for Spitfires (a MK1 specifically)?
billspit Bill Kea
Only one I know about is Quaife and they are over $1,200.
yellowbookroad Avatar
yellowbookroad Gareth T
Somewhere in, Estonia   EST
1970 Triumph 2.5 PI MkII "Permanently NICKED Nickname"
Quaife are rubbish. They simply don't work.
I've built LSDs for Spitfires for near 30 years inc the original salisbury fitted in the Le Mans car, inc ADU3B. (I used to have one in my road car).
The only worthwhile LSD is a PLATE TYPE.
There are 2 done in the UK now, (Tranx and Gripper), and another salisbury was remanufactured in Australia for the dolomite.
The price is quite high, but sure as anything no-one would ever bring me to lower the price ever again.
(You get fat thanks for helping people out, all they want is freebies!)
hymodyne Avatar
hymodyne james king
salisbury, MD, USA   USA
1972 Triumph GT6 MkIII "Baby Blue"
Mention made here of LSD options.
http://www.triumphspitfire.com/substitute.html
spitlist Avatar
spitlist Joe Curry
In reply to a post by yellowbookroad Quaife are rubbish. They simply don't work.
I see he's BACK! Actually, Quaife is not all that bad. It's biggest problem is that it is torque biased and if one wheel is off the ground or axle breaks(offerning no resistance on one side) it won't go anywhere. There are other options as Gareth suggests. I guess it all comes down to what you intend to use it for. One option is welding the diff so that both wheels turn simultaneously. This is NOPT recommended for daily drivers.
Joe
P.S. Don't fall for "Phantom Grip". I tested one (thanks to GT6 Steve) and found that they are (as Gareth would put it) RUBBISH. I could not see any difference in that and and open diff.
Edited 1 time(s). Last edit at 2011-10-17 02:03 PM by spitlist.
We tested the Quaife back to back against a Salisbury in our FIA championship winning car in 1993.
The German co didn't believe me when I could get their car 2-3 seconds a lap faster...
They said "PERFECT" car...German style!
Funnily enough when we changed from that crap Quaife to a good second hand Salisbury, the car made that 5 seconds a lap difference IN THE WET.
In the dry it was even faster.
I spent ages convincing them..."sigh"!
I also worked on the Le Mans TR2, and they also said I couldn't make it better German style again!
I managed to build in some castor, get proper feel into the steering, then the magazine that reviewed the car thought it was "b...marvellous".
Said they had never driven a TR2 that was so nice to drive....
'nuff said really.
crap Germans, crap LSDs, Quaifes, been there done it, seen the video, read the book.
This is what you want:-
Edited 2 time(s). Last edit at 2011-10-17 03:07 PM by yellowbookroad.
racer490 Jerry Bryant
Palm Harbor, USA   USA
I didn't see one advertised for spitfires They ran 980.00 US for other TR's
Bodge Garage Avatar
Bodge Garage Kris Schmidt
Spokane WA, USA   USA
I wonder if the original poster is not racing the Germans? Maybe there is a time and a place for other options. Just a thought.
Herald948 Avatar
Herald948 Andrew Mace
What about the "Detroit Locker"? At one time, it was offered through the US Competition Parts program for Spitfires as well as other Triumphs. I don't know much about them or any other LS diff. so I don't know how it compared to the Salisbury unit, etc.
Kma4444 Avatar
Kma4444 Kevin Allen
Anderson, SC, USA   USA
The locker is a strange animal to drive. Robust and reliable but you have to drive them differently. They are an open diff off the throttle and when you go back to throttle they lock the rear wheels together like a welded diff or spool. SO you get a good turn in and when you go back to the throttle it points the nose out of the corner, very unsettling until you learn to drive it.
I always ran a locked diff in the race car, it is the right choice for a swing axle Spit. It tends towards corner entry understeer which helps the Spit with it's high rear roll center. Makes it where you can really hang the car on it's rear tires getting in and then when you go to throttle, you drive it off using your right foot to point the nose. Great fun and fast when you are HP limited.
Where can I find any of these limited slip differentials? I have a welded differential in it right now. I am planning on using it for vintage racing but I also want to take it to autocrosses every now and then and a welded differential sucks for that. I have driven plate type differentials versus torsen style in the same vehicle and I found the torsen was better.
Edited 1 time(s). Last edit at 2011-10-18 07:43 AM by 96DXCivic.
In reply to a post by Kma4444 I always ran a locked diff in the race car, it is the right choice for a swing axle Spit..
WRONG choice.
With this style of driving you will ALWAYS be slower.
Initial turn-in is one of the great unsung advantages of the Triumph cars.
Blasting into the entry of a corner with the front wheels pointing extremes and understeering means you will also run into the dive/castor/chassis flex mess the car is known for on the DOWN SIDE.
If you like it, fair enough.
It's SLOWER, just like it is on a mini, which also had good initial turn in, but then shed loads of disappointing speed penalising understeer.
Fast initial turn in means you can come in, brake MUCH later, then get on the right lines without going all over the place.
Locked diffs are absolutely hopeless for this.
Carrying high speeds into the corner means higher exit speeds, even if you have to be "slow in, fast out".
"slithering" your way around corners is nonsense, maybe looks and feels good, but sux on the stopwatch.
If you ever did any karting, you would see fastest is CLEANEST, > usually least spectacular., and heck THEY have locked axles from the word go, so they understeer/oversteer like crazy!
Brake late, turn in, > slow in FAST out.
The heavier and faster car you drive, the MORE you have to observe it.
Try 500bhp behind you, & see how you get on with a "locked diff"!
The proof is, ALL the modern lightweight Jaguar E type boys now moved from Salisbury LSD plate type axles, to Modern multi plate type LSD with variable ramp angles.
The results are blistering fast, ESPECIALLY in the wet!
60-40
70-30
ramp angles are the BIZ.
Forget locked diffs, they belong to the museum or in the back of lightweight cart.
(NB, if you want a LSD it takes some time to make up, and you have to choose a ratio, not just mention "I would like one".)
Edited 2 time(s). Last edit at 2011-10-18 08:27 AM by yellowbookroad.
Kma4444 Avatar
Kma4444 Kevin Allen
Yeah, of all the things I was called in the Spit, slow wasn't one of them.
In the ALMS Viper, we got the car from Canaska with a spool, it was the way we had to run it initially as we didn't have the $9k for the viscous one that Oreca was by then running. luckily, one fell off the truck at Daytona and we put it in the car at the track. It was magic and transformed the car.
My Trans-Am car had to run the locker or a spool, it had a locker in it when I got it and I hated it. I had planned on swapping to a spool and setting up around it and am convinced on that chassis it would have been faster. Recently I spent three weeks in Denmark and did a couple races in American GT1/ Trans-Am cars and that chassis worked very well with the locker. I would leave the lockers in those cars because they were very good.
My point, every car is different, every driver is different. I have run some 200+hp FWD cars with the Torsen and they were absolutely seamless. I also run one in my sportsracer that again is seamless, you never notice the diff at all. Again, blanket statements are as useless as arguing on the internet.
The OP wanted opinions and those are mine. My choice for what he is doing is keep the welded one for racing and get a good plate style or secondly the Quaife for autocross.
Where can I find a Tran X differential for the Spitfire?
May I ask why they don't work?
From talking to a couple other people, I am getting the impression that helical style differentials are better for daily drivers but clutch types are better for track cars.
Edited 2 time(s). Last edit at 2011-10-18 05:10 PM by 96DXCivic.
1965 Triumph TR4A
