Driving the mainshaft bearing into the gearbox case.
jhdubois Jeremy DuBois
Hudson, MA, USA   USA
I'm currently rebuilding a three-rail gearbox for a GT6 MkIII I'm restoring, and I'm about at the point I can put it all back together after replacing about half the parts in it. Reverse was mostly obliterated, and the syncro teeth on 2nd and 3rd were worn badly from running a while on used up rings, and of course the one thrust washer that's hard to find was in four pieces.
Anyway, I'm contemplating getting this all back in the case and I'm not quite sure how to get the mainshaft and its bearing back in place without the factory tool that mimics the input shaft to hold the mainshaft centered and at the correct depth while you drive the bearing into the case. I see there's a guy currently on eBay selling the correct Churchill tool for $150, and I'll bite the bullet and buy it if I have to, but just wondering if anybody else had any clever method to do it without the tool? I could probably fabricated something, but that might be more trouble than $150 is worth. I could just insert the input shaft first, but I don't really want to be banging on the little roller bearing that fits between the input shaft and the mainshaft.
You can use a drift or a socket handle to line it up before you clamp it down.
14GPDJENGINEERING Avatar
Silver Spring, MD, USA   USA
Here is what I use.
Dennis smiling smiley
TransTools 002.jpg    29.8 KB
Hudson, MA, USA   USA
Clever, thanks guys!
Hudson, MA, USA   USA
For the curious, this is what I came up with. Should get the job done!
Jeremy, Check my Journal on that, mine was simple enough and makes it easy.
On the synchro's , check what you had and what you got as replacements. The GT6 is a little wider than the standard Spitfire.
Hudson, MA, USA   USA
In reply to # 1513117 by trrdster The GT6 is a little wider than the standard Spitfire.
Hmm, the new synchro rings I bought were part #150328, which is the part specified in both the GT6 Mk3 and the Spitfire IV/1500 factory parts manuals. They match the old ones that were in the gearbox.
OK, that's good, the early 3 rail had a little different one.
Hope you got it all together by now.
Hudson, MA, USA   USA
In reply to # 1513209 by trrdster OK, that's good, the early 3 rail had a little different one.
Just to be confusing, I suppose winking smiley
In reply to a post by trrdster Hope you got it all together by now.
Waiting for my new 2nd and 3rd gears to arrive, then I can measure end float and adjust thrust washers, and finally get it all back together. No rush though, the body is still waiting to go to the media blasting shop and then off to the body shop. I won't actually need the gearbox back together for a long while yet. Just figured I'd get it out of the way and onto the completed list. Thanks for the help!
I understand that, Doug and I are waiting to paint with warmer weather.
I got a 3 tier old bread rack and filled it up, heavy stuff on the bottom. Wasn't big enough. LOL
Nice to get the running gear on the frame.
Have fun.
1961 Triumph TR3A
