Turned aluminium dash?
Wolfcreek Steve Steve P
Central, WI, USA   USA
In reply to # 1512383 by Hot Spit Just a tip, in order to do a perfect job you will need to some how be able to index the part in exact increments. That way the spots will overlap uniformly. I can't picture that being done on a drill press without some kind of fixture. Impossible to do by hand.
Yup! I use a mark on the part and a 4' "yard stick". The big trick is holding the part on the small drill press table.
Attached photo was done on a drill press using a 2" scotchbrite pad on a rol-loc arbor. Dashboard would be done with a smaller diameter tool.
IMG_2938.JPG    47.2 KB
Brad.Cogan Avatar
Brad.Cogan Bradley Cogan
1989 Toyota MR2 "Coral"
Looks awesome. I'd love to do it properly with a real bit of SS or aluminium. Unfortunately I have limited funds, limited space, limited tools and limited skill. Bought some turned aluminium vinyl. It's quite thick and looks good. Will apply when I get the time to take the dashboard apart.
Brad Cogan
Hot Spit Avatar
Hot Spit Mike Stefanakis
Wethersfield, CT, USA   USA
I found this for engine turning. Note that he has a small panel on a Bridgeport milling machine where he can index the table to within .001". Also available is engine turned stock. Check it out.
https://www.hotrodhotline.com/content/engine-turning-dash-panels-etc-jim-clark-hot-rod-md#.Wn4rSqiKS2w
http://www.fpmmetals.com/automotive/
69gt6stopp Avatar
69gt6stopp Paul Stopp
Richmond, BC, Canada   CAN
I found that with a random orbital sander and not too course a grit you can get some interesting regular patterns. This is the application I used on my 1/8" thick sheet alum, dash panel I made up. Unfortunately the photos attached do not show the swirl pattern that was achieved.
Regards, Paul
Full view Dash.JPG    60 KB
Short shifter & old knob.JPG    49.6 KB
1968 Triumph TR250
