Door check seal ?
skyking1231 Avatar
Mt. Sinai, NY, USA   USA
grubscrew Avatar
grubscrew grub screw
It seals the door check strap at the A post.
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
N5329K Avatar
Pacific Grove, CA, USA   USA
In reply to # 1511744 by skyking1231 Where does this seal go....or how does it go?
http://www.spitbits.com/store/16-DOOR-CHECK-SEAL-MK41500-2req-P4122.aspx
It forms a watertight gasket around the small square opening in the aft face of the A pillar where the check strap passes through. The door closes against it and presses it tight. The two little clips grip the sides of the hole, but the seal also has holes made for using small sheet metal screws, if you prefer.
Robin
skyking1231 Avatar
ok....what threw me off was the two holes....so they are optional...or perhaps from another application/car ?
since i have nothing else to work on, on my car (i guess that is a good thing)....i am going to tackle my door locks...which i think are not hooked up.....and other door hardware that may be missing....
grubscrew Avatar
Optional? Well I guess you could say that...the car will run without those seals! winking smiley
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
skyking1231 Avatar
ha....
i meant the holes...
as bare and basic as a spit is...lots of things optional..... top, heater, door locks (stick shift is the anti-theft device), and so on....
In reply to # 1511839 by grubscrew Optional? Well I guess you could say that...the car will run without those seals! winking smiley
Manana Avatar
Manana Steve Wten
Thornhill, ON, Canada   CAN
Installation....
Steve
A-Post Horizontal Bars for Check-Strap.jpg    23.7 KB
IMGP9120.jpg    53.6 KB
1969 Triumph Spitfire MkIII
