REAR DIFF.
REAR DIFF.
  This topic is about my 1969 Triumph GT6+ (MkII)
68mustang Avatar
68mustang George Cardoso
West Hartford, CT, USA   USA
LOOKING FOR A SPITFIRE REAR DIFF. TO INSTALL ON 68 GT6 + ALSO LOOKING FOR 3.63:1 RING AND PINION GEAR SET
OR A SPITFIRE DIFF. WITH 3.63:1 GEAR ALREADY INSTALLED.
fmcboy2012 Avatar
fmcboy2012 Martin Wilson
Baltimore, MD, USA   USA
you should try john at quantum mechanics...http://www.quantumechanics.com send an email to: JOHN@QUANTUMECHANICS.COM and he will get back to you. he is busy so calling him usually does no good. but he is the best.
M
Growe58 Avatar
Growe58 Greg Rowe
Hatfield, PA, USA   USA
One of the TR7 diffs is a 3.63. I think it's the earlier one that goes with the 4 speed manual. I believe that you have to swap in the spitfire stub axles and drill the front for the Spitfire mounting carrier but other than that, it's a straight swap. If you search the archives, I'm sure you will find details. Just a way to widen your search, if you have trouble finding a spitfire one.
1968 Triumph TR250
