Rack prelaod adjustment?
GeorgeOhr Nonya Business
Yes, confused, USA   USA
My rack doesn't have any slack but it doesn;t have any preload or dampening. How do you go about adjusting preload on these? Thanks
I don't believe there is any special preload except what is built in with the assembly of the unit. There are springs on each end that are part of the steering rod inner assembly. Nothing else that I saw when rebuilding mine.
jimgt6 Jim E
Seekonk, MA, USA   USA
Quoting from the factory manual:
When the nut is correctly adjusted, a force of 2 lb. is required to rotate the pinion shaft at a radius of 8" (16 inch pounds). Parenthesis added by me.
There are shims under the cap nut.
Edited 1 time(s). Last edit at 2018-02-02 10:38 PM by jimgt6.
If there is no slack, don't fix it.
jimgt6 Jim E
Lube is 90w GL4
In reply to # 1511164 by jimgt6 Quoting from the factory manual:
There isn't anything that drags on the rack gear itself like some type of plunger?
In reply to # 1511198 by GeorgeOhr
George,
Yes there is a damper plunger under the big hex plug. Shims there adjust the damper. There are also shims on the pinion itself to adjust the mesh.
1980 Triumph Spitfire 1500
