2 holes behind seats to the left/right of the tunnel?
70tbolt Geoff Ullmann
Morgan Hill, CA, USA   USA
Can anyone tell me what these holes are for? There are 2 more on the opposite side.
Thank!
Geoff
Holes behind seats.JPG    18.7 KB
Geoff, I'll take a shot at it.
Someone has removed the bolts that hold the bracket for the radius arms. Even though the GT6 was last produced in 1973, Triumph didn't change the body molds for that panel. Still there on the 1980's ones.
GT6 roto flex.used one side and the Spitfire the other on each side..
Fix it by putting a couple of bolts in there, fine thread 7/16, I think.
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
Do you have radius rods? They're a big part of the rear suspension.
In reply to # 1511064 by trrdster Geoff, I'll take a shot at it.
'S all for now
Vic
Thanks, that makes sense. Will use rubber plugs.
Geoff
No. I think what happened is that the previous owner who started the restoration left the holes exposed when he installed the insulation. Probably forgot that they were not going to be used. Car has the standard 1975 set up.
Geoff
carChips Avatar
1933 MG Magnette
You might want to look at this page, https://rimmerbros.com/Item--i-GRID005748 In particular item # 155930R and their associated hardware.
They are important bits of the suspension.
'S all for now
Vic
The radius arms are there but are bolted to the left & right of the holes in question. I can't see anything under the car that would use those holes.
Geoff
I just found this picture the previous owner sent me when the car was being stripped. To the left you can see where the radius arm is bolted and the holes in question have bolts in them.
Geoff
thumbnail.jpg    48.9 KB
planebow Robert Howard
Kalispell, MT, USA   USA
Those holes in my 71 has rubber plugs in them.
This shows it from the rear, suspension side, the holes just below the e-brake cable. This is a 69 body but they all have them in the same place. At least all of mine do.
other side I the same. On my other 69 these had rubber plugs in them. This car did not so they were probably pulled by a PO at some point.
69 floor pan 7.JPG    48.8 KB
Auldman Andrew Kelsey
Ramsey, Isle of Man, UK   GBR
I agree- be reassured, they are certainly nothing to do with any part of the suspension.
Originally, they will have simply had rubber bungs in them.
As to their function? - I do not know.
This is just a guess, but I think It is possible that once the car had left the production line, they had no function ar all.
Various holes in such places as the boot/trunk floor and the holes in the inner sills/ rocker panels were more to do with giving access during assembly-for the arms of spot-welding machine for example.Those on the exterior were then sealed off with rubber bungs.
These particular holes are too small for that, but perhaps they were to secure that body part during assembly possibly in a jig.
Someone, somewhere will know...
Geoff,
Wayne has the right idea. That panel was designed to accommodate both the Spitfire suspension and the Rotoflex GT6 set-up. The trailing arm bracket for Rotoflex has to be mounted closer to the center of the car to make the geometry work. When the panel is used on a Spitfire, the Rotoflex holes are plugged. When used on a Rotoflex GT6, the Spitfire holes would have been plugged instead.
Cars built before the Rotoflex GT6 was introduced don't have those extra holes.
In reply to # 1511358 by spitfire50
Geoff,
I am sure you’re right! - your explanation makes perfect sense to me now.
quikrx Ralph Hansen
Antioch, IL, USA   USA
1962 Triumph Herald 1200
1987 Mazda RX-7 "Mistress"
Spit radius arms used the holes closer to the outside of the body - Gt6's with roto-flex used the inner set - on a Spit you can used the inner ones but WILL NEED to get longer radius arms (have them made with heim joints also) and the toe change over travel will be reduced (out of Spit Comp Prep Book - will also need the additional bracket inside tub to reinforce the area ( works well and my Spit and Herald will both get this mod)
spitlist Avatar
spitlist Joe Curry
Didn't we beat that subject to death on Facebook? smiling smiley
1959 Triumph TR3A
