Convertible top buttons on body...
agassi70 Aaron Graeb
Daphne, AL, USA   USA
I am trying to find the best way to attach the snaps/buttons to the body. I have tried pop rivets and the head doesn't seat all the way in the button and stays loose and doesn't pull the rivet all the way to mount tight. Is there a different way? My top comes in Monday and I would like to be ready. Thank you and I'm sorry if I missed a thread on here.
Roy Avatar
Roy roy o
Marietta, GA, USA   USA
I used a couple of washers as spacers to allow contact with pop rivet tool head
JOEVACS Avatar
JOEVACS Joe Carter
Hickory, NC, USA   USA
I used a spacer to go inside the snap socket ( can't remember where I got it from ), between the pop rivet and the gun. stacked washers or nuts would work too if you can find some small enough to go down into that spot. You do want the surface of your spacer to be as wide as the rivet top though or it will pull partially through it and weaken it ( and look ugly )
N5329K Avatar
Pacific Grove, CA, USA   USA
Unscrew the top off a spare spark plug and use it as the spacer in the rivet gun. It works.
Robin
MoneyPitSpit Avatar
MoneyPitSpit Ron (Smokey) Wasmuth
Beautiful, Sparkling, Lakeland, FL, USA   USA
1974 Triumph Spitfire "Midnight Blue"
1995 Chevrolet Camaro "Crystal Blue Persuasion"
I used 2 #8 lock washers as spacers between the rivet head and the rivet gun. Worked like a charm.
JOEVACS Avatar
JOEVACS Joe Carter
Great idea Robin !
I found a tip adapter for my rivet gun for going down into spaces like snaps. before that I used small washers that just fit over the rivet pull wire and placed it on the wire then inserted into the gun. The correct adapter was the best answer.
CraigL Avatar
Santa Clara, CA, USA   USA
I would also use a backing washer on the inside of the body to firmly seat the pop rivet.
Agree with others on slipping something over the shaft of the rivet before inserting it into the gun.
I found some short threaded brass spacers in my computer junk that worked.
Bobs78Spit Avatar
Bobs78Spit Silver Member Bob Berger
St. Louis, MO, USA   USA
You have to be careful with slipping something over the shaft of the rivet. When the rivet gun pops the spacer can go flying and possibly ding your paint. I have a couple of marks on the tops of my doors from when I installed the snaps for the tonneau cover.
Born Loser Avatar
Land O Lake, FL, USA   USA
I just ran the rivet gun tip over the grinder, until it was small enough to fit in the snap. That worked well, and I didnt have to worry about keeping up with the spacers after the steam snapped off.
Matthew
1960 Triumph TR3a
1970 Triumph Spitfire MK 3
2018 Jaguar F-Pace
In reply to # 1507115 by Bobs78Spit You have to be careful with slipping something over the shaft of the rivet. When the rivet gun pops the spacer can go flying and possibly ding your paint. I have a couple of marks on the tops of my doors from when I installed the snaps for the tonneau cover.
I forgot the mention the little magnet tool attached to the tip or held there with the other hand. I discovered that need after the first try.
In reply to # 1507169 by Yellowhawk Valley
I use a shop cloth.
jimgt6 Jim E
Seekonk, MA, USA   USA
In reply to # 1507073 by N5329K Unscrew the top off a spare spark plug and use it as the spacer in the rivet gun. It works.
Robin
The sparkplug top is a great idea. You might have to use the mandrel from a longer rivet so the tool will grip.
