cylinder head plugs?
spoon12342002 Avatar
spoon12342002 Eddie S
Milton, VT, USA   USA
Looks like 2 plugs at the end of the head, can these be removed?
Of course.
(the real trick of course is replacing them)
Sure.
I belive they are normally included in a full core plug set, but they are not anything special, you should find something at your FLAPS.
Use a little sealant when fitting the new plugs.
1973 Triumph Spitfire MkIV
