head off block
Andy-Sherry Avatar
Portland, OR, USA   USA
I got some 3/4 dia pipe cut to 1" lengths attached to head with silicone over studs and filled with PB blaster and left to sit
Andy&Sherry
1974 Spit 1500 Carmine Red
Always learning something
grumpicus Steve Jackson
In reply to # 1505526 by Andy-Sherry I got some 3/4 dia pipe cut to 1" lengths attached to head with silicone over studs and filled with PB blaster and left to sit
Yup, sounds familiar! Ideally, leave it for a couple of weeks, too!
spoon12342002 Avatar
spoon12342002 Eddie S
Milton, VT, USA   USA
2 days later and i got the head off! Lots of Pb blaster and heat. Next question, do i need a valve spring compressor tool to get the springs off or somebody know a trick?
Eddie, see if you can rent a spring compressor from your local auto parts store.
If not, make a flat plate that goes across the length of your head, drill holes in it where the rocker towers are bolted in and use that as leverage with a fork tool, like a ball joint separate on top of the valve. Watch your fingers getting the keepers out, use needle nose, you can thank me later.
tapkaJohnD Avatar
tapkaJohnD John Davies
"Breaking the head off" by turning over the engine only leads to a leaking head gasket. Even the "Rope Trick" only shifts head a little.
Thing is, it's the head sticking to the studs, by crud in the space around them, not the head to the block, so pushing the head up a little gets you nowhere.
And double nutting can work, but condemns the studs, and the nuts. You were going to replace them anyway, weren't you?
A really, really reluctant stud can be shifted by WELDING the nut onto it. Then turn it out with a spanner.
The heat, concentrated in the stud, will help loosen it.
BUT, turn it first to tighten, and then turn it out like cutting a thread, one way then the other. And if it starts to squeal, STOP. The stud could break.
Retighten it, more penetrating oil, wait a while, try again.
Good luck!
As Wayne says, it is best to rent/ borrow a spring compressor. But all sorts of devices can be made.
I used to use a 2x2, one end chained to the bench, a 'crows foot' metal bracket on the underside in the mid section and a rope stirrup (for you foot ) tied to the end.
With block of wood cut to fit over both valves in the combustion camber, the cyl head is laid on the bench, the crows foot bracket is seated over the valve spring cap and the spring compressed by foot action untill the collets pop loose.
As said, it is best to remove the collets with needle nosed pliers. .......Ask me how I know that!
KEEP THE VALVES IN ORDER!
Milton, VT, USA   USA
Springs are off, rented a tool from Advance Auto. Valve guides gonna have shop press them out. What springs and valves size should i go with for street performance head? Shooting for 9:1 compression pistons.
Twin Lakes, WI, USA   USA
If the studs corroded inside the head, it could be cracked. Could also have been a blown head gasket. I recommend checking that head really carefully before putting a lot of work into it.
In reply to # 1505625 by spoon12342002 Springs are off, rented a tool from Advance Auto. Valve guides gonna have shop press them out. What springs and valves size should i go with for street performance head? Shooting for 9:1 compression pistons.
The larger (post 73?) Valves are normally favoured, even though some owners clain the combustion chamber shrouds the valve.
The valve springs you chose should work with the cam chosen. Many cam suppliers specify seat pressure or advise on the use of a particular spring.
In reply to # 1505613 by Tonyfixit
Hi,
I have had good luck loosening any collets that are stuck with a pick and getting them out with a magnet.
lef2wander Avatar
Hatfield, MA, USA   USA
In reply to # 1505595 by spoon12342002 2 days later and i got the head off! Lots of Pb blaster and heat. Next question, do i need a valve spring compressor tool to get the springs off or somebody know a trick?
I used a habor frieght spring compressor($8.00). It's a little big you'll have to form the catch's a little. I don't think it will work for install. A piece of pipe with cutouts and a drill press will work.
www.homemadetools.net
Edited 1 time(s). Last edit at 2018-01-03 08:15 AM by lef2wander.
The stock Spitfire valve springs are not very strong, you can just lean on them and compress them.
Also, they are nice and straight, perpendicular to the top and bottom surfaces of the head.
I've used a drill press (not spinning of course) or even an arbor press for the job.
https://www.harborfreight.com/1-ton-arbor-press-3552.html
Tape a little block of wood in the combustion chamber to prevent the valve from opening when you depress the spring.
A magnet is handy for snagging the keepers when they pop loose.
Plenty of tools out there that will do the job:
https://www.tooltopia.com/otc-tools-4572.aspx?utm_source=bing&utm_medium=cpc&utm_campaign=PLA&scid=scbplpOTC4572&sc_intid=OTC4572
http://www.sears.com/abn-2130-8-valve-spring-compressor/p-SPM12333143030?plpSellerId=AutoBodyNow&prdNo=21&blockNo=21&blockType=G21
Brad.Cogan Avatar
Brad.Cogan Bradley Cogan
+1 on the string method.
Take out no 1 spark plug and feed in as much string as possible into the cylinder then stick the car in fourth and push it forward. The piston will press against the string then the head and push it off.
You may need to do this for no 4 too if it's really stuck. You should be able to wiggle it until it comes loose once the string has cracked it open.
Brad Cogan
1964 Triumph Spitfire 4 MkI
