recommended front spring compressor ?
JohnW63 John Williamson
Apple Valley, CA, USA   USA
I have both a center shaft compressor kit I used on my Mustang, which can't be used on the GT6, since the shock lives in there. I used the pair of screws with hooks on the top and bottom type, today, but what i don't like about them is that they can tend to twist around the spring and move kind of suddenly when they do. There is really nothing to keep them from wanting to follow the contour of the spring in a spiral. My Dad sent me a video showing how I SHOULD have been installing the shock and spring as an assembly, but I still would like a better compressor kit.
Anyone have a link to a good set ?
cmfisher4 Avatar
Mystic, CT, USA   USA
John,
I fought the same fight...and ended up building my own. The things are just too small to fit modern spring compressors, let alone the MacPherson strut ones. If you have a welder, or maybe even can bolt an equivalent together, it's definitely the way to go. You can find LOTS of references to it, but here's mine.
HTH and Cheers!
Chris
Born Loser Avatar
Land O Lake, FL, USA   USA
We have been down this road a time or two - if you dont find a suitable solution here, try a quick search for "Spring Compressor" in the Spitfire forum, all dates. You will find a ton of reading.
That said - with my patented "You will shoot your eye out" warning - here is Grahams solution - http://www.triumphexp.com/phorum/read.php?8,1305709,1305709#msg-1305709
Matthew
1960 Triumph TR3a
1970 Triumph Spitfire MK 3
2018 Jaguar F-Pace
No welding skill here, but my wife got me a dimming helmet for Christmas, so my talk about wanting to learn has taken seed.
In reply to # 1505196 by JohnW63 No welding skill here, but my wife got me a dimming helmet for Christmas, so my talk about wanting to learn has taken seed.
Some local community colleges offer non-credit classes for free.
This is the one I made a couple of years ago. Very similar to one shown above. I used a piece of angle on the bottom so I can clamp it into the vice then use two ratcheting box wrenches to run the nuts up and down at the same time. I have seen some small mods to this style where the builder will run a third rod up from the bottom to try to be an extra safety catch but as long as the shock is inside the coil it, the spring, can't go anywhere.
I too tried the outside claw sort of clamp once and was so nervous about the movement that I built this one instead. I have included the original plans created by another Dan. You can see I did a few slight mods for mine. I can also slide a double ended rod connector down from the top to thread onto the top of the shock to ensure there is a rod extending out the top until the spring is completely loose.
Good luck with it all.
Spring comp 2.JPG    43.5 KB
Coil Spring Compressor.pdf    254.2 KB
rcharris Rod Harris
Fort Collins, CO, USA   USA
And, here is the one I made. I can’t remember where I got the aluminum channels,
I also spent money on a FLAPS compressor, which is back in its box, looking for a new home.
Best of luck, and Happy New Years!
rc
FDFCEFE2-CC15-464C-83D0-12D87FA71F33.jpeg    40.1 KB
I used ex "Tools 'n More" spring compressors and can say they're too big.
arturo64 Avatar
arturo64 Arthur T
Billings, MT, USA   USA
I just found a set up that is much like what was just posted above but firmly attaches to the spring. I’ll post a pic when I bolster the courage to go to my garage.
Arthur
68 spit
70 gt6+
IanF Ian Furqueron
Croydon, PA, USA   USA
I have one of these:
https://www.amazon.com/Goplus-MacPherson-Interchangable-Compressor-Extractor/dp/B017H1AWMK/ref=sr_1_25?ie=UTF8&qid=1514820371&sr=8-25&keywords=spring+compressor+tool
The smallest plates work well enough. I also wrap a compression strap around the assembly to make me feel better. I work on a lot of modern cars, so one tool for them all is beneficial. I also have an OTC Strut Tamer tool that I've used to swap out many Spit springs, but unless you can set it up permanently it's a bit of a PITA to use and not really meant for a home mechanic.
arturo64 Avatar
arturo64 Arthur T
Here’s the one I’m gonna be trying. Can’t see how it won’t work...but ya never know.
Arthur
68 spit
70 gt6+
92782B9D-78C0-4E8E-AFB5-EA97EE864345.jpeg    47.1 KB
In reply to # 1505474 by arturo64 Here’s the one I’m gonna be trying. Can’t see how it won’t work...but ya never know.
Arthur,
Lack of room between the spring and body of the shock may be the problem. That is usually where that type has its downfall.
Fictioneer Avatar
Fictioneer Doug Hirt
Rolled my own a few years back out of some scrap aluminum plate, threaded rods, steel tubing, and a small bottle jack. Works great and is very fast.
Spring Compressor - Triumph Spitfire.jpg    19.4 KB
I like all of these home built compressors. If I could build them quickly, I might take a run at something like that. I really don't expect to need to use this tool more than twice, to get the two front shocks in, and be done. This assumes my springs are not worn out and let the car wallow around too much. Building one of these would be a great project, if I had to do this more often.
This is the video my Dad sent me, to show the error of my attempt to install things the wrong way.
He seems to use a low tech pair of compressors that have double fingers on one end and a hook at the other. It also seems to have some extra U bolts to help keep things in place, I think.
arturo64 Avatar
arturo64 Arthur T
The little u bolt is the only thing that goes between spring and shock so I’m thinking it’ll work. But it will be a long while to finding out as the snow is to high and temp to low for messing around.
But Doug wins....hydraulics....that’s just cheating.
In reply to # 1505480 by spitfire50
Arthur,
Arthur
68 spit
70 gt6+
