Rebuilt 1147 won't turn over
Andy-Sherry Avatar
Portland, OR, USA   USA
When i replaced bearings i put one rod in wrong way round,motor will not turn over as cap hits the inside of block
Andy&Sherry
1974 Spit 1500 Carmine Red
Always learning something
In reply to # 1505305 by Andy-Sherry When i replaced bearings i put one rod in wrong way round,motor will not turn over as cap hits the inside of block
I don't think that would be the case with a 1147.
I would say, the pan definitely has to come off.
I hope the OP dosent just keep turning it in the hope it might get better.
In reply to # 1505311 by Tonyfixit
It's been so long I don't remember now, I automatically set the rods pointing the right way.
But 1147 rods and crankcase are essentially the same configuration as 1296 SJ.
The 1147/1296 crankcase is rather tight ... so much so that the 1500 crankcase casting had to
be 'ballooned' out to provide enough clearance for the 0.45" longer stroke
Not for the larger rods ... the 1296 BJ uses the same larger rods, crankcase is same size as 1147/1296 SJ.
balloonfoot Avatar
balloonfoot Gold Member Lloyd Faust
Southlake, TX, USA   USA
In reply to # 1505139 by Tonyfixit
In reply to # 1505111 by balloonfoot
In reply to # 1504963 by ccren89 This summer I picked up a 66' triumph spitfire that came with all the le mans bits.
new on this forum. What are "all the LeMans bits"?
The Le Mans Spitfires looked like this.
I know what they looked like, however when he said "LeMans bits" I was wondering if he meant 8 port head etc for the 1147..................
An 1147 8 port head would be a rare chunk of Iron indeed.
I have not heard of anyone reproducing them.
I would imagine the OP just has a Hood (bonnet) kit.
balloonfoot Avatar
Yah, a guy used to race a Spit with VARA in the 90s with the head and webers....in fact had 2 of those SAH supplied heads. Only ones I have ever seen anywhere.
That's why I was curious.
Edited 2 time(s). Last edit at 2018-01-01 04:11 PM by balloonfoot.
Dale M. Avatar
Tell City, IN, USA   USA
I once had a mustang that when installing a new engine, one wrong bolt that was too long was used the install the fan. Took me awhile to realize it
1977 Triumph Spitfire 1500
