Spitfire wheel specs
  This topic is about my 1973 Triumph Spitfire 1500
christrish Avatar
christrish Chris B
Lehi, UT, USA   USA
Getting ready to post a set of 5 Spitfire wheels in the Buy&Sell section, but I want to be sure I include all the correct info and verify that they are all the same.
What markings should I be looking for? I've seen 4.5x13 and 5x13 sizes listed in other ads.
Working to take the "D" out of DPO since 2013
Follow my restoration progress: http://73spitfire1500.blogspot.com
IMG_3769.jpg    35.5 KB
IMG_3773.jpg    47.1 KB
IMG_3770.jpg    51.6 KB
Some of the wheels will have the size stamped into the rim somewhere. Not sure all of them did but I have seen a few with the stamps. Those look original so they should be 4.5, 5 or 5.5 x 13.
Spitfirejoe Avatar
Spitfirejoe Joe Guinan
Fremont, NE, USA   USA
In your second pic, at almost the 9 o'clock position, you can see the size stamped in the wheel center just inside the ventilation holes. It looks like they are 4.5 inch wheels, though I wasn't able to see it clearly when I enlarged the photo on my computer. I think it says "4.5 x 12 x 88". The "88" indicates the offset of the wheel, and I think the stock 4.5" wheels had a 22 mm offset.
Look here for more info - http://www.triumphspitfire.com/wheels.html#factoryinfo
Joe Guinan
Fremont, Nebraska
christrish Avatar
christrish Chris B
Lehi, UT, USA   USA
Thanks Dan and Joe. In that link, it says the "88" refers to 0.88" offset (22mm). I'll check all 5 rims to make sure they're the same.
HI,
Instead of the markings shown above some Spitfire wheels have the width and diameter stamped on the rim in line with the attachment of the center in larger characters. For example I have one marked RSM 42 4 1/2 J x13 R. The only marking on that wheel that would show when a tire is mounted is LP875 stamped a little closer to the hub than the marking shown above.
Spitfirejoe Avatar
Haven't seen one like that, Paul. Do you have any photos you could post?
Joe Guinan
Fremont, Nebraska
Joe,
Just tried to get a pic or two. Typical, camera battery is too low. The one I have is a late Mk3 Spitfire or early GT6 wheel. It doesn't have ventilation holes, just slots where the center joins the rim.
Spitfirejoe Avatar
Like this one?
Joe Guinan
Fremont, Nebraska
s-l1600.jpg    56.9 KB
Joe,
Looks right.
christrish Avatar
christrish Chris B
Lehi, UT, USA   USA
Here's a few pics. All are 4.5x13x88. I sandblasted one before I got a different set of wheels.
Edited 1 time(s). Last edit at 2017-12-30 03:34 PM by christrish.
IMG_3804.jpg    56.5 KB
IMG_3802.jpg    22.1 KB
IMG_3799.jpg    48.2 KB
IMG_3800.jpg    46 KB
1978 Triumph Spitfire 1500
