Stutter after releasing accelerator
How is it if you engage reverse (from a standstill) does it grind?
I wonder if the clutch is dragging.
You say it moves violently when applying the throttle. Is this with the clutch fully engaged, just applying the throttle? Are there noises, perhaps from the rear end when this happens? Like a clang.
How sloppy is the gear lever when the car is in gear? There should be little movment.
1974 Triumph TR6
