Fuel Pump Identification
PumpGuy123 Timothy Jordan
Boston, USA   USA
Hello,
Could someone tell me what model fuel pump this is? It has ID numbers 7050389 and en32b on the handle part. What range of Triumphs does this fit on?
Thanks, and happy motoring.
IMG_0904.JPG    57.2 KB
IMG_0901.JPG    38.2 KB
IMG_0902.JPG    40.5 KB
IMG_0903.JPG    45.1 KB
Looks like the OE pump that came off my 74, and just about as crusty.
I would not trust that diaphragm, time for a rebuild. If I remember rightly, my pump was an AC.
claytoncnc Avatar
Clean up and rebuild that early pump.
New diaphragm and valves it will deliver at the correct pressure for another 40 years.
It should fit all cars, but it is probably from a mk1 or mk2 that had that short priming lever
Edited 1 time(s). Last edit at 2017-12-28 05:49 PM by claytoncnc.
Boston, USA   USA
Would it be worth $50?
claytoncnc Avatar
It is a far better quality item than the new ones, but it would need some time and money spent
http://www.goss.com.au/products/631VC
It is worth what someone is willing to pay.
In reply to # 1504808 by PumpGuy123 Would it be worth $50?
Rebuilt after ultrasonic cleaning etc. I guess it's possible someone might buy it.
Why?
Herald948 Avatar
Herald948 Andrew Mace
I'm not sure I'd pay that much. However, if someone were to at least clean it off, and if there are no broken bits or other damage, I'd give it some thought. Like Marcus said: new valves and diaphragm would likely keep your grandkids' enjoyment of your car pretty much trouble-free!
Full disclosure: 1. I've paid less for better looking rebuildables. 2. They'll also fit Heralds! grinning smiley
spits Avatar
spits paul krause
Sunnyandhot, FL, USA   USA
1968 Triumph Spitfire MkIII
1969 Triumph Spitfire MkIII "Rusty; Gone But Not Forgotten!"
The forged lever arm is the key. No replacement pumps have it. Non-OEM pumps use a laminated approach. Some even resorted to a folded sheet metal implementation that had a bad habit of fatiguing and leaving the arm in the oil pan.
Bottom line--good piece of hardware.
Best,
Greg1835 Avatar
Greg1835 Greg S
Rudolph, WI, USA   USA
I do like the priming lever on the older pumps.
Boston, USA   USA
Get the pump while it's still $1.00. Bid now and sell it for more later!
Click Here for the eBay link
Fictioneer Avatar
Fictioneer Doug Hirt
Who sells replacement parts for the original AC fuel pumps? TRF sells kits for the TR4A pumps but I've not seen them for the Spits.
Boston, USA   USA
This individual restored a fuel pump using parts from The Roadster Factory. Buy it while it's still up there! (My Ebay Link)
