Bad choke?
Bad choke?
  This topic is about my 1970 Triumph Spitfire MkIII
techwiz001 Matthew S.
Winston-Salem, North Carolina, USA   USA
Hello everyone!
I have a 1970 Spitfire MkIII, and with the recent colder weather, I have had some issues driving right after startup.
With the idle speed screw tightened enough for the car to hold an idle when it is started from cold, it idles at about 1700rpm once it has warmed up.
My understanding is that this may be due to a failure in the car's electric choke (it has a Weber carb), but I am not totally sure. How can I verify that this is the issue? Is there anything else that could cause this?
Thanks for your help.
Not sure how the electric choke works on those carbs but often you can just unplug it and it will go full open. Or, just loosen the clamps and make sure it is full open when it is fully warmed up by adjusting it.
When it is fully warmed, does quickly tapping the throttle release the fast idle set? If not, that may be where your adjustment needs to be done.
