3 rail vs single rail o/d
Las Vegas, Nevada, USA   USA
In reply to # 1501151 by balloonfoot What is interchangeable between the 3 rail and the single rail Spitfire O/D transmissions?
Sounds like one or the other is about to be available.
Melbourne, Victoria, Australia   AUS
I've just completed a single rail g/box internals into a 3 rail box with a J type O/D. The 3 rail casing had to be the Mk4 or Vitesse/GT6 306468 box remember the single rail mainshaft with J type O/D is 1in longer and will need a 1in spacer annulus between the gearbox to O/D adapter and the J O/D. Also you need a spacer washer on the reverse selector to avoid selecting rev & 1st simultaneously. Another thing from left field for me was I had to bend the reverse selector lever forward about 1/8in. Besides which you'll have to check replace several the mainshaft spacer/adjustment washer's.
The reason I went down the 3 rail path was the cost of the alloy bellhousing for the single rail with protruding selector shaft, I had 2No. 3 rail alloy bellhousings one early Herald thinwall and one thicker same as cast iron unit.
I can supply more info if wanted,
Regards
Peter T
3 Rail J Type OD with 1500 internals.jpg    37.9 KB
grumpicus Steve Jackson
Peter - I'm interested in your comments about engaging 1st & reverse simultaneously. Some of the later single rail boxes (maybe those with the larger teeth on the reverse gears) do partially engage the reverse idler gear with the reverse teeth on the synchro hub in 1st gear, which can lead to some strange noises in 1st. It's a known issue, probably just a consequence of squeezing larger components into a fairly small casing without spending the cash on a gearbox redesign. Also, the bending of the reverse gear lever - I've heard of this being done, presumably to give better engagement of the idler gear when reverse is selected? Or maybe to move the idler away from first gear?
When I built my close ratio box, I used components from a late Dolomite 1850 OD box, which had the later reverse gears with fewer (& larger teeth), and the later first gear on the mainshaft. (Early single rail boxes used the 'thinner' 1st gear, and the later ones got the TKC3001 'thicker' gear. Introduced across the range around 1977 to help prevent the 4 speed TR7s from stripping teeth in 1st gear.... eye rolling smiley ) I think I may have used the thicker single rail spacer, 22G1435, on the reverse idler shaft, but I think that was about it.
It's the first time I've seen the 1" thick spacer ring fitted to enable the single rail OD mainshaft to be used with the three rail adaptor plate. I had considered using the single rail mainshaft with the single rail OD adaptor plate, but decided against it, on the basis that I didn't really want to change the propshaft - and I already had a three rail TKC899 mainshaft with J type OD. I machined a steel sleeve for the mainshaft tip, to increase the diameter to 15mm, and bought a hardened needle roller inner sleeve to increase the outer diameter to 18mm. All were a press fit, with a drop or two of loctite for good measure.
Regards
Steve
I too had a TKC899 J type O/D shaft with the thin/small input tip, purchased from Mike Papworth a few years ago, and bushing it up to fit the later 1500 input shaft was too daunting for me so I went down the path of a 1500 gearset with its O/D mainshaft RKC767. The main reason was I'd purchased a Midget 1500 engine and non O/D gearbox locally. I already had a J Type O/D which I'd rebuilt with a full new pump, filters and reco cone clutch, & I'd also purchased the adapter plate 313085.
Some where I'd read about the two gear selection issue and the reqd reverse selector shaft spacer washer 158585, I had researched what was reqd over a couple of years & had to thank the TSSC Forum, Mike P and a blast from the past John Kipping (NZ) who was very forth coming. I had purchased the later 3 rail g/box casing 306468 ex US/NY and single rail 1500 O/D mainshaft RKC767 ex US/Texas. Also most of the spacer washers were also ex US, with some from Rimmers.
The reverse selector spacer washer was very rare it's only a washer but I didn't know its thickness, asking around on the various forums didn't come with the answer then whooa on ebay from the US again.
Ref the 1 inch spacer it was an Eureka moment after trying to slide the O/D down the mainshaft and being sure the splines aligned it just wouldn't slot home. Fortunately a neighbour has a large gear manufacture business and made the 1in adapter annulus for me, and finally success!! but I had to make longer studs.
Ref the reverse selector lever I hit it hard with a 3lb lump hammer but was too scared to take it all the way 1/8in, so I drilled a hole above the pivot pin halfway thro the lever, hacksawedthro the lever to it , then knocked the lever over the 1/8in and got a very good welder to weld the slot up, so good was the job no filing was necessary.
I also have a Dolly 1850 single rail gearbox with J type O/D which I want to adapt for my 68 Mk2 Vitesse (owned it since 70), so as I have to use the GT6/Vitesse alloy bell housing I will have to either adapt the bellhousing for the single rail selector shaft protruding out the front OR go down the route of putting all the single rail gearset into the 3 rail casing 306468 AGAIN, whether I'd use the TKC899 mainshaft and bush it up, or the RKC767 single rail 1500 mainshaft currently in the dolly O/D box and fit another annulus adapter I'll have to sleep on that one.
Hope that explains why and where, I'd like to have used a Spit 4, 3 rail J type O/D set up easy peasy, but in Aus there very very rare, ie not obtainable like Spit Mk3 1300 engines.
Regards
Peter T
Peter - thanks for the explanation! For what it's worth, Mike Papworth sells uprated TKC899 shafts - he takes a NOS single rail non-OD shaft, and machines the correct splines etc. for the J-type OD into the plain section of the shaft. It ends up being exactly the same length as a standard TKC899 shaft, and the new splined section is re-hardened. I had considered buying one of those, but as I had a spare TKC899 shaft and a small lathe, I thought I'd try the sleeving method. I'd already bought a remachined input shaft for the gearbox, rebuilt the OD, so it was starting to stretch the budget!
My neighbour the gear manufacturer wouldn't cut & machine the original non O/D single rail mainshaft as his testing showed the case hardening to be too hard to satisfactory machine, then re-harden that part. Hence my purchase from the US of a good S/H unit.
For interest Hardmans also do an overdrive conversion for the Toyota Land Cruiser auto box as a bolt on, the O/D is an American unit, which is a direct copy of the old Laycock unit. Marks 4X4 is the subsiduary company.
I think I've answered my own question re the Vitesse J type conversion I'll use the small tip TKC899 mainshaft bushed larger to fit the input shaft, as I brought from Rimmers a Vitesse special propshaft for J type conversions & I don't want to have to cut it 1in shorter if I use the large tip & longer RKC767 mainshaft.
Unfortunately US postage is quite expensive, the usual courier way can be twice that of internal postage and courier for the international trip, but the sellar has to be prepared to do some local running around! A g/box case 306468 would now cost around $40 with $110 postage vs one last year only $60 postage via US internal mail and O/S courier.
Similar the ebay UK international postage has gone mad nothing less than 20 pounds where as if the seller will post by what was the old "International air mail small packets" or it's current version it's so much cheaper, Rimmers, Numpty & the more usual suppliers still use the older method. I think the ebay system is tracked and signed for, some items just ain't worth that cost!
Ahh the cost of living in the sun!
Peter T
Trident750 Jeff D.
Livermore, CA, USA   USA
Tony,
I have a late GT6 input shaft I’d like to adapt to a TR7 modified mainshaft. I received with a large box of GT6/TR7 gears. Do you know the full complement bearing you used to accept the larger mainshaft tip?
Jeff
Peter - I can't comment on the case hardening issue with the remachined non-OD mainshaft, but it occurs to me that the splines on that shaft have to transmit a lot more torque in the lower gears than a remachined input shaft, which only has engine torque (plus any shock loadings) to deal with! If the rehardened input shaft on mine fails, it's just a simple matter of finding & fitting a standard 1850 Dolomite single rail input shaft, making a 1" spacer to fit between bellhousing and gearbox, finding a clutch plate to fit the Spitfire clutch and Dolomite input shaft, and shortening the propshaft.......
The 306468 case you mention seems to be the one for the GT6 Mk3 and the early Dolomite 1850 with the three rail box - the only difference I'm aware of between that and the 149140 three rail case for the Mk4 Spitfire & Toledo 1300 is that the GT6/Dolomite 1850 version has three holes in the front face for the laygear anti-rattle springs. I'd be inclined to use the Spit Mk4 case, shim the layshaft for minimum endfloat, and forget about the anti-rattle springs. If you really wanted to fit them, you could always drill the three extra holes, but the standard springs can put an excessive load onto the laygear thrust washers, and can score the face of the laygear. I did actually fit the springs in my gearbox, but cut a turn off each spring to lessen the load on the thrust washers, and reduced the laygear endfloat with slighthly thicker shims. The Spitfire 3 rail gearbox casings are still ten a penny in the UK!
Regards
Steve
