Quick oil pressure sending unit question
cbez Cole B
Fallbrook, California, USA   USA
My sending unit compression nut broke. Will a
standard compression fitting secure the small plastic hose that goes to a mechanical sending unit?
The one that was on it looked different. (Attached)
1971 Triumph Spitfire MK 4
20171201_103308.jpg    28.8 KB
Yes, I think it is a 1/8 inch one and yes standard should work on the nylon tube.
cbez Cole B
Ok thank you I'm freaking out a bit this morning.
grubscrew Avatar
grubscrew grub screw
In reply to # 1500762 by cbez I'm freaking out a bit this morning.
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
cbez Cole B
In reply to # 1500772 by grubscrew
I finished new fuel pump install and the compression nut broke and sprayed oil all over my driveway. Then I had to figure out how to fix it in time to get to work.
20171201_083732.jpg    51 KB
20171201_084942.jpg    39.9 KB
I've actually been to Fallbrook.
My sister used to live there, and I visited for the weekend during a business trip a few years ago.
Definitely Sports Car driving territory !!
cbez Cole B
In reply to # 1500782 by clshore I've actually been to Fallbrook.
Yeah it's a nice place for it and the weather is great.
Cole,
Too late now, but the easy answer to that broken sender fitting is to disconnect the gauge and fall back on the idiot light. That way you aren't rushed to put the gauge back under pressure when perhaps you should take your time and make sure everything is 100% first.
cbez Cole B
In reply to # 1500821 by spitfire50 Cole,
I couldn't find a cap to cap off the new hole in the block.
Cole,
The original oil pressure switch will screw directly into the block. Unscrew everything else and put the oil pressure switch in the hole. Job done.winking smiley
cbez Cole B
In reply to # 1500828 by spitfire50 Cole,
Don't believe I have one.
Las Vegas, Nevada, USA   USA
Figured the obvious wasn't an option for a reason.
Cole,
It really isn't the best to have the gauge and no oil pressure warning light. The obvious change when that green light comes on in front of you is much more effective in getting attention than a gauge needle running low. There has been extensive discussion of the best way to connect both to the engine at once on this forum, so I won't go into that again here.
If you don't hook both up, a 1/8" NPT pipe plug will seal the block port in an emergency. Not a bad thing to have on hand in the tool kit.
In reply to # 1500866 by spitfire50 Cole,
Good tip Paul. Although these are available at just about any hardware store, the chances are, when it happens to me, I won't be in the vacinity of a hardware store.
Frankly, if that green light goes on while driving you'll wonder why it isn't red.
After all, you're supposed to STOP.
