Column mounted DImmer Switch
In reply to # 1498334 by Herald948 Thanks, Dan! Funny, the link works for me! winking smiley
It didn't work for me either. Must have lost something on the link set up. Maybe the direct link will work if not just grabbing the one I attached does work. (Thanks for the copy Andrew)
www.fairpoint.net/~herald948/database/wiring.htm#3 EDIT: Nope, this direct copy will not work either - the wonders of the net. da
Edited 1 time(s). Last edit at 2017-11-17 08:43 AM by Yellowhawk Valley.
Herald948 Avatar
Herald948 Andrew Mace
I give up. It's something about this Forum software that still thinks it's 2014 and my site has been hacked (long since cleaned up and preventative measures put in place)! Nothing personal, Skye! winking smiley
Edited 1 time(s). Last edit at 2017-11-17 10:33 AM by Herald948.
regnaston Dale Sanger
Anyone have a picture of what item 43 looks like (Dip Switch according to the wiring diagram).
headlight.JPG    12.3 KB
Las Vegas, Nevada, USA   USA
Like this?
In reply to # 1500302 by Doug in Vegas Like this?
Item 38 is labeled as Steering Column Light Switch I have one of those (with 5 wires instead of the 3 in your pic)
TinDrum Herald Ma
cologne, NRW, Germany   DEU
Herald
s-l1600aa.jpg    83.6 KB
Always thought the floor switch was superior to a stalk switch.
A metal turn indicator lever and a center mount horn would be nice.
Wonder if the older model will bolt on or there needs to be an adapter fabricated. Do it at the u-joint?
mkivmarty Avatar
mkivmarty Marty Yanik
N.E.Ohio, USA   USA
In reply to # 1500333 by Doug in Vegas Always thought the floor switch was superior to a stalk switch.
I had one of those in an old Mustang. With the clutch and the brake, you needed a third foot to drive it on the back roads at night!!. I much prefer the column switch.
Marty
In reply to # 1500318 by TinDrum Herald
isnt that the floor switch?
grubscrew Avatar
grubscrew grub screw
In reply to # 1500361 by regnaston
Yes, for dipping the high beams.
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
In reply to # 1500377 by grubscrew
I have the column one.. I want to know however what the item 43 is in the diagram
Quote: have the column one.. I want to know however what the item 43 is in the diagram
The diagram is showing the floor mounted dip switch. Like the one in Heralds picture.
In reply to # 1500401 by Yellowhawk Valley
then what is 38 for? I assume you dont have both a column mount and a floor mount in one vehicle.. but the wiring diagram shows it?
grubscrew Avatar
In reply to # 1500403 by regnaston then what is 38 for?
What does the diagram call it?
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
In reply to # 1500404 by grubscrew
38 "Steering column light Switch"
43 "Dip Switch"
